SOLVED Use my own mailserver
AndyInNYC
I set up my PBX forever ago. gmail no longer sends my voicemails (yes, I know why), so it's time to fix the problem (past time to fix the problem).
My PBX is using sendmail and was configured from the 'use gmail as a smarthost thread' long ago.
I'm not sure what files to change and how.
my /etc/mail/sendmail.mc
my mail server (for discussion), is AndyInNYCMail.com
I have an account [email protected] with password "Cow".
My server uses ssl, password authentication and port 587
Help for the stupid?
Andrew
if you "still" want to stay with gmail, you need to setup app password. Once app password is setup...
update /etc/mail/auth/client-info with new app password Gmail app key
then run the following:
chmod 600 client-info
makemap -r hash client-info.db < client-info
cd ..
make
systemctl restart sendmail
then immediately run
echo "test" | mail -s testmessage youremailaddress
to make sure it works...
Once you have your APPpassword from google -
The APPpassword simply replaces your regular password in /etc/mail/auth/client-info
And then run @Brianmac 's code above.
Well that should be quicker than troubling to set up a Non Google mail relayhost as above link.
I'm really not a farmer, so I can't really judge - but your joke really was the cream of the crop, ostridge.
Actually, I haven't decided on your joke - I'm half and half ...
Ok, jokes aside. getting an app password fixed the issue.
Thank you for looking out for your mentally deficient cohort.
