GO HERE Endpoint manager for pbx2022 r-18
mayoor
I just installed pbx 2022 r-18 on crowncloud is it possible to install oss endpoint manager? is there a writeup?
OSS Endpoint Manager should be available in FreePBX GUI Settings if it is installed. Otherwise, you can install it in Module Admin.
See this Nerd Vittles article for setup tips.
Tried to install polycom and got this error
PDOException (HY000)
SQLSTATE[HY000]: General error: 1364 Field 'firmware_vers' doesn't have a default value
Now the error disappeared uninstalled codec
My mistake it said installed and went to mapping and showed no package installed, uninstalled and tried to install same error .... didn't install
package manager shows installed and all other menu items says no packages installed
