Can't really say, I prefer sandisk but since I started using them I haven't had a failure, if you need lots of storage , then an ssd is probably a better way to go.Hi dicko, thanks. Would you consider using a WD Purple wear-leveling microSD card in an RPi to be in the same reliability ballpark as using an SSD a la Ward's posting? Or if not, at least good enough? I realize that this is an impossible question.
