ostridge
- Jan 22, 2015
- 1,816
- 630
VM.Standard.E2.1.Micro oracl provided Image: Canonical-Ubuntu-22.04-Minimal-2023.03.17-0.
On new always free E2.1 AMD OCL VM I did an apt update and apt upgrade and it finished with
OK do I need either or just reboot ? Please advise.
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
Adding boot menu entry for UEFI Firmware Settings ...
done
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78.)
debconf: falling back to frontend: Readline
Scanning processes...
Scanning candidates...
Scanning linux images...
Pending kernel upgrade
Newer kernel available
The currently running kernel version is 5.15.0-1030-oracle which is not the expected kernel version 5.15.0-1032-oracle.
Restarting the system to load the new kernel will not be handled automatically, so you should consider rebooting.
Restarting services...
Daemons using outdated libraries
1. networkd-dispatcher.service 2. unattended-upgrades.service
(Enter the items or ranges you want to select, separated by spaces.)
Which services should be restarted?
