TIPS Problems setting up on windows 11
When I do the pbxstatus command it shows a few of them offline as you can see
Well those are some of the Incrediblepbx 'bells and whistles' - applications which are useful but not set up yet.
See the Incredible Ticky Wiki .
'Webmin' is a third party offering we can use to look at various aspects of linux servers from a GUI in your browser. Do google for webmin.com - you may have to download the latest webmin offering for your Linux (ubuntu) platform (or virtual linux image).
Openvpn is for the Virtual Private Network that can be used to make a direct route to your cloud server if any. it is installed by default but not started unless configured. See the Incredible Ticky Wiki .
Faxgetty / IAX modem / and HYLAFAX are for the IncredibleFAX offering. These are also not set up or not installed. Again see the Wiki tutorial articles that cover most things, in such a way as they just work.
how do I get web admin panel thing i dont see anything about getting that setup anywhere
You need to set up Virtual Hosts see UCP is not working -SOLVED
Time to check the log files.
/var/log/asterisk/full
where am i supposed to put the register thing?
Have you configured the trunks correctly? do you have an outbound route setup?
The log file will tell you what's wrong.
Then you need to provision your trunks correctly, so the registration is not rejected
No mind readers here.
Your registration attempts has failed. I'm not a magician! Read the log file and diagnose your issue. They are rookie mistakes.
where in the settings would the username they are getting me?
I thought the trunks but they are saying they are getting the username liquid and i cant find the username liquid anywhere on the dashboard
Show us your trunk configuration. Connectivity > Trunks
i got it registered! Still getting the all circuits are busy error tho
Have you setup an outbound route and dial pattern?
And there is no trunk defined in that outbound route.
