Joe Diamond CPA
- May 5, 2022
- 292
- 106
Hi everyone, all of sudden 2 weeks ago incoming calls only rand 2 times before IPBX answered, not it is about 8 rings! any ideas?
Hi kenn, always great to hear from you, I'm using incredible pbx 2021 15.0.37.9, all calls go from time conditions to IVR, always use either SIP or PJSIP trunksNeed more specifics. What is the incoming call coming to? IVR, Ring Group, Extension, Call Center Queue?
Is the incoming call on a SIP trunk, ISDN-PRI trunk, analog trunk?
What version of FreePBX?. What version of Asterisk?
I've had no FreePBX-17 updates that affected my systems.
thank you, but using IPs not fqdn.When I had this happen in the past, our upstream provider had fqdns for our sip trunk primary and backup. Their SBC would be giving 180 ringing to the caller while looking up/resolving the fqdn, before finally sending the INVITE to us. Did away with fqdn. Direct to IP address and issues resolved.
Asterisk 18.2.0, running script now. ...will do ken, hold please.......
apt install sngrep to add it to your system.SSH into IPBX, will not run that command?
Using that link I posted, you should be able to either install it, or compile it.yes it is centos
Live Chat
Video Conferencing
Check your inbox!
