madgen
- Jun 3, 2025
- 16
- 18
All,
Big update to the FreePBX Dial Plan Vizualizer module!
This release adds a bunch of quality-of-life features and visual improvements to make managing dial plans and extensions a lot smoother:
Installation / upgrade: GitHub - madgen78/dpviz: Dial Plan Vizualizer module for FreePBX
Previous releases: Releases · madgen78/dpviz · GitHub
Let me know what you would like to see next.
Thanks for all of the support and suggestions. - and if you’d like to keep up with future updates, consider
starring or following the project on GitHub.
-Adam
- Dynamic queue member login status is now displayed.
- See Asterisk DND / Call Forward status at a glance.
Queue pause status detection included.- Tooltips now show user agents and voicemail counts.
- Consistent tooltips across queues, ring groups, and extensions.
- Added Next / Previous buttons for dialplan navigation (works with search!).
- Extensions now appear in the dialplan dropdown.
- New options: Allowlist, Blacklist, and Auto-play audio.
-Adam
