DEAL Hostodo VPS Special $12/Year
wardmundy
Nerd Uno
We launched odo, the official Hostodo CLI.
You can now deploy VPSes, SSH into instances, manage invoices, add SSH keys, and script provisioning directly from your terminal.
Install:
brew install hostodo/tap/odo odo login odo deploy odo ssh my-server
To kick it off, we made a set of one-off CLI launch plans.
No promo code needed. Annual, 2-year, and 3-year terms available.
Tampa, FL + Las Vegas, NV only.
Detroit is limited and not part of this drop.
Important: the $12/year 1GB plan is very limited. If you want that one, grab it first. Once the small pool is gone, it is gone.
CLI launch specials
1GB RAM / 24GB NVMe
1 vCPU · 3TB bandwidth VERY LIMITED
Annual$12/year2-year$24/2 years3-year$36/3 years
Order Tampa
Order Vegas
2GB RAM / 40GB NVMe
2 vCPU · 4TB bandwidth
Annual$24/year2-year$46/2 years3-year$66/3 years
Order Tampa
Order Vegas
4GB RAM / 75GB NVMe
2 vCPU · 6TB bandwidth
Annual$36/year2-year$69/2 years3-year$99/3 years
Order Tampa
Order Vegas
8GB RAM / 120GB NVMe
3 vCPU · 8TB bandwidth
Annual$64/year2-year$122.67/2 years3-year$176/3 years
Order Tampa
Order Vegas
16GB RAM / 180GB NVMe
6 vCPU · 10TB bandwidth
Annual$99/year2-year$189.75/2 years3-year$272.25/3 years
Order Tampa
Order Vegas
24GB RAM / 300GB NVMe
8 vCPU · 12TB bandwidth
Annual$179/year2-year$343.08/2 years3-year$492.25/3 years
Order Tampa
Order Vegas
64GB RAM / 520GB NVMe
12 vCPU · 15TB bandwidth
Annual$599/year2-year$1,148.08/2 years3-year$1,647.25/3 years
Order Tampa
Order Vegas
odo is open source:
https://github.com/hostodo/odo-cli
Docs:
https://hostodo.com/docs/cli
Try it, break it, and send feedback.
Thanks,
Hassan
Hostodo
Still some left. Tampa site is zippy quick and 1GB RAM VPS works fine with Incredible PBX 2026 and Debian 13.
I have had Hostodo for 3 days now. I have not been able to connect to the VNC since I signed up. I have had several tickets and replies but They have not been able to fix the issue of connecting with the VNC. The price is great but just can't connect. Any suggestions
It's a standard VPS deployment. Have you tried accessing your VPS with a browser or SSH??
Tampa or Las Vegas?
That worked nice and easy. the email didn't finish installing. What can I do to repair it
If you mean Postfix still shows DOWN, then you haven't run /root/enable-gmail-smarthost-with-postfix with your Gmail account name and Gmail App Password.
Yeah, that's not the problem at all.
This doesn't update pbxstatus at all. It never replaces "sendmail" with "postfix" because nothing matches.
sed -i 's|SendMail| Postfix|' /usr/local/sbin/pbxstatus
Even then if it did match on SendMail, having a space and Postfix is wrong because
ps aux | grep -c Postfix
would return a 1 and thus still show being down because it's only matching on itself.
When pbxstatus is updated properly to postfix pbxstatus works just fine without running the gmail smarthost which does nothing to fix the issue because it doesn't impact the status of postfix initially.
Whatever you say, @Samot. Works as advertised for the rest of us:
db2300
