Joe Diamond CPA
- May 5, 2022
- 309
- 115
i have VitalPBX3 running great with extensions and trunks PJSIP, trying to set up VPBX4 (of course PJSIP) and in my home network (the PBX's are both set up at Crown Cloud, so no porting or port issues) using the groundwire app, for some reason i cannot dial out using my home wifi with VPBX4, but no issues dialing out on VPBX3 , i tried to set up VPBX4 the same as VPBX3. note, the groundwire app is connected to VPBX4 , if i check reports, pbx reports PJSIP endpoints, I have a green dot and it shows my home public IP. Is something not set up properly with NAT? networs settings? THANK YOU
