NEW Outbound SMS FreePBX Module
wardmundy
Nerd Uno
We've had so much fun dusting off our old Raspberry Pi devices, we decided to tackle building an actual FreePBX module to handle outbound SMS Messaging for Incredible PBX 2026 as well as the RasPi platform.
Prerequisites:
1. Incredible PBX 2026 platform or Incredible 2027 platform with new PJsip (not existing SIP) trunk named VoIPms-Registered.
2. A voip.ms account with at least one DID configured to support SMS. Please use our signup link which helps fund our dozen honeypots that protect Incredible PBX platforms.
3. A PJsip trunk enabled on your Incredible PBX 2026 platform for voip.ms. Required: Use the default VoIPms-Registered trunk provided with the iPBX 2027 distro or roll your own PJsip trunk on iPBX 2027 and name it VoIPms-Registered.
4. A default Outbound Route using your VoIPms-Registered Trunk
5. If you've experimented with Raspberry Pi SMS setup, delete [sms-outbound] context from extensions_custom.conf
Installation:
cd /tmp
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/sms-outbound.txt
cat sms-outbound.txt >> /etc/asterisk/extensions_custom.conf
asterisk -rx "dialplan reload"
fwconsole ma downloadinstall https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/smsrouting-1.1.17.tar.gz
fwconsole reload
/root/sig-fix
/root/sig-fix
Operation:
1. From the FreePBX GUI, choose Connectivity -> VoIP.ms SMS
2. In Trunk Configuration, enter 10-digit DID and one of the VoIP.ms POPs, e.g. atlanta2.voip.ms
3. Click Save Settings and Apply Config
4. In Send Quick SMS, enter 10-digit destination number and message to deliver via SMS
5. Click Send SMS
SMS messages sent through VoIP.ms are $0.0075 each. Licensed for use pursuant to GPLv2+.
@Samot: Your constructive comments are always welcomed. But the endless drivel about what you perceive to be the unreliability of SMS messaging is tedious, and that's being kind. Take a break and go pester the nice folks on the FreePBX forum.
TIP: Should you ever need to change the name of the voip.ms PJsip trunk, you'll need to change VoIPms-Registered in both
(1) the [sms-outbound] context in /etc/asterisk/extensions_custom.conf and also
(2) in /var/www/html/admin/modules/smsrouting/Smsrouting.class.php
Then:
chown -R asterisk:asterisk /var/www/html/admin/modules/smsrouting
fwconsole reload
Then:
fwconsole reload
good sunday ward! question.................in IPBX 2026 i set up the SMS module and can successfully send out SMS BUT to nnly other voip.ms numbers?? it will not send to my t-mobile cell number?
Sounds like a ticket to ask questions from voip.ms and T-Mobile who can answer that
Yep. They are tracking down a problem sending from some VoIP.ms DIDs. Mine in area code 904 send out just fine. Several others in various area codes all fail.
opps, thank you KNERD! LOL
thanks, but it is wierd that i can successfully SMS from IPBX 2026 to another voip.ms DID but not my t mobile cell?
I bet it has to do with T-Mobile. Often, VoIP providers have issues with mobile carriers for some reason I do not know. Probably has something to do with robocalls and SMS spam.
