SUGGESTIONS CRM for Incredible PBX and PIAF
CapnBio
I am looking for a CRM software to integrate with piaf and/or incredible pbx(tried googling I didn't get the results I wanted). Basically I just want to get everyone under there when they call in, they have the reason typed in, kind of like a call log (which we do manually by hand on paper) since I really want to save paper.
Any ideas? I'm open to suggestions.
Yes, sugarCRM. Works pretty well for basic stuff, and the community edition is free.
I was able to get it up and running but I am having a little bit of trouble getting it to work along side ipbx.
It depends on your needs. A lot of small-medium businesses tend to go with SugarCRM. Salesforce is always reliable too, both for small and large organizations. There's also MS Dynamics with a lot of relevant functionality. That's just to name a few. And if you're looking for a way to integrate PIAF with these systems of record/CRMs, I suggest that you check Tenfold. One of its features is automatic call logging. All your calls—inbound and outbound—is automatically saved in the CRM. It saves time by eliminating useless clicks and yes, it saves you paper.
Tenfold's other features include click-to-call which converts all phone numbers in the CRM or on any part of your browser into clickable hyperlinks, a caller ID/screen pop that can show relevant customer info, and a call analytics dashboard that can be used for reporting and gamification of call activities.
I already wrote here in Forum that is possible to use Informity Module to do an integration of Incredible PBX with Bitrix24, but this will be an expensive solution when you have a small company.
Any suggestion to use a CRM with Incredibile PBX? or Anyother Solution?
Thank you for your time and attention
Odoo 20 community (free open source) would be good for you to try for CRM with VOIP call logging IMHO.
1. Using the Free Open-Source Way (OCA Telephony Modules)
The Odoo Community Association (OCA) maintains a suite of open-source telephony modules (known historically as asterisk_click2dial) via their connector-telephony GitHub repository.
  • How it communicates: It completely bypasses the browser's audio layer. Instead, it utilizes direct XML-RPC calls from Odoo straight into the Asterisk Manager Interface (AMI) on port 5038.
  • The Workflow: When an agent clicks a phone number inside Odoo CRM, Odoo sends an AMI command instructing Asterisk to ring that specific agent's physical desk phone or desktop softphone client (like Zoiper or Linphone). Once the agent picks up, Asterisk dials the customer.
  • Inbound Lookup: On incoming calls, an AGI script on Asterisk queries the Odoo API to pull the customer's name and flash it as the Caller ID.
Are any CRMs supported by iPBX ?
would it be hard to get an iPBX version since there is pretty good support for Odoo and FreePBX ?
https://github.com/datalabsystems/odoo19-freepbx-voip-guide
https://community.freepbx.org/t/odoo19-freepbx-voip-integration-guide/109147
https://www.odoo.com/forum/help-1/connect-odoo-to-asterisk-freepbx-252761
This OCA voip module should work fine with IPBX, it communicates thru the IPBX WebSockets interface, not UDP or TCP, just go into IPBX, enable WebSockets, and configure the OCA voip module with the IPBX hostname and websockets port.
Thanks.
That looks like it does the Odoo -> VOIP part of things.
This module allows the use of VOIP directly from Odoo.
It relies on SIP.js to connect to the PBX using a websocket directly from the browser.
The 3CX odoo integration (just released) will pull up the Odoo CRM record as the call is answered, which could be very helpful.
carareal
