Joe Diamond CPA
- May 5, 2022
- 304
- 109
just finished testing, all works well, just one issue (not really an issue0 BUT if you put in an alternate callback number the recording says press 1 to accept, when you do this it repeats itself and again says to press 1 to accept, then it works. WE ALL SHOULD GIVE A BIG THANKS TO KNERD! I sent hin $500 for his efforts in making incredible PBX a real contender as a modern PBX!! P.S. i am having trouble having the PBX listen for faxes? i followed wards instructions for installing faxing on IPBX 2027 and then the additional script installation to modify it for IPBX 2026? but not answering faxes? any help would be appreciated!Queue Callback Beta 5 is now available...
IMPORTANT: Custom return-call recordings must instruct customers to press 1 to connect.
Release v17.0.5.0_Beta5 · tcreek/queue_callback_v17
Queue Callback 17.0.5.0 Beta 5 New features Return-call confirmation: Customers must press 1 before connecting, preventing voicemail answers from being treated as completed callbacks. Configurable...github.com
Also available for download here.
Code:cd /var/www/html/admin/modules mkdir qcallback chown asterisk:asterisk qcallback chmod 775 qcallback cd qcallback wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/qcallback-17.0.5.0_Beta_5.tgz tar zxvf qcallback-17.0.5.0_Beta_5.tgz cd agi-bin cp -p * /var/lib/asterisk/agi-bin/. fwconsole ma install qcallback /root/sig-fix /root/sig-fix fwconsole reload
