Cepstral Swift vs. Saytext
bullet117
When I use Swift in the extensions_custom.conf file I get NAG "This voice is not licensed" if i use SayText in the extensions_custom.conf it works fine.
When I tried to register the license with swift --register it wouldn't work, it kept giving me "The information you have entered is invalid!", the only way I could register it was using Digium's Register program.
I was wondering if there is any difference between Swift and Saytext commands when used in the extensions_custom.conf file or anywhere else.
I had the same problem. Sent email to Digium and they told me to use the register program and "SayText". That's ok unless you need to create custom recordings. I can't manage to do that without the nag. Not much help from Digium.
Mike
I have seen this when the Voice Name you enter is not exactly correct.
The way its listed on your email from Cepstral - It looks like this:
Allison-8kHz for Linux (v5.x)
What you really must enter is only this much of it:
Allison-8kHz
Let me know if this helps -
Allison-8kHz
tshif, I tried with Allison-8kHz, the key from Digium is different then what you get from Cepstral the Digium key is CEP-XXXXXXXXXXXX vs. the key from Cepstral is xx-xxxxxx-xxxxxx-xxxxxx-xxxxxx-xxxxxx
Digium provides free support. You might want to give them a call. ;)
