Fresh 1.4 Install, Things going wild
rossiv
I installed PIAF 1.4 today, and things have been pretty strange. My CPU will go to 100% at random moments, and it said (before I did anything at all to it) that I already had one extension registered. I had not done that. Also, the RSS feed disappeared from the Kennonsoft menu for a short time. That was due to the whole server loosing connection to the internet and not being able to connect to any website except local resources. A reboot fixed the internet problem, but I still can not call out or get calls in because it seems that Asterisk has "crashed". What would do this?
I am re-installing PIAF 1.4 now, and right after it starts to compile Asterisk, I get a message saying:
CPU0: Temperature above threshold, cpu clock throttled (total events = 1).
Should I be concerned? I know the CPU just got hot, but I have not seen that ever before.
Yep. It was only there when it was installing. Have not seen it again.
Sounds like a serious hardware problem.
:iagree: Any and all other weirdness you experience could easily be caused by an overheated CPU. Trouble shooting software on troubled hardware is a total waist of time. Under these circumstances - we'll never really know whats going on, and why your troubles occur. Job ONE is resolving your underlying hardware issue.
