Can PIAF/Asterisk place a call to multiple phone numbers at the same time?
tdnnash25
I want to know if you can place a call to multiple phone numbers and deliver the same message? For example, let's say you need a message to go out to 10 people all at the same time - and play the same audio file...Instead of creating 10 reminders all set for the same time, can you just type phonenumber1, phonenumber2, phonenumber3, etc for the recipients? I tried this with 2 numbers and it didn't work. So, I'm wondering if there is something in the config that I need to tweak ... or maybe something with my trunk? If anyone can help me out, I'd sure appreciate it.
Confused
Check www.nerdvittles.com for the RoboDialer routine. Works great for this.
I found a tut on Asteridex and Robodialer. I installed Asteridex4 but when I get to this step of Nerd Vittle's tut, I don't have the conf file listed: "
The dialplan code that will be inserted below requires the trunk number for the channel that will be handling the outbound call. If you're running PBX in a Flash with FreePBX, point your web browser at the IP address of your Asterisk server. Then choose Administration->FreePBX and log in with admin username and password. Next click Tools->Config Edit->extensions_additional.conf. Look at the Global variables OUT_1, OUT_2, etc. Identify the numbers of the ones for the VoIP providers you want to use for placing outbound calls. Then close the extensions_additional.conf file. "
Do I have to install Asteridex to have Robodialer? All I want is to be able to setup call reminders that go out to multiple people/phones at the same time and play the same message. Do I need more than 1 outbound trunk to handle this?
Are you familiar with connecting to your server via putty or terraterm or the likes?
if so I always use the locate command
locate extensions_additional.conf
should yield
/etc/asterisk/extensions_additional.conf
therefore do a nano -w /etc/asterisk/extensions_additional.conf
this is also discussed here http://pbxinaflash.com/community/threads/asteridex-script-is-ready.265/
I believe Edisoninfo meant to point you to the TeleYapper4 article.
On a side note, another easy way (if you're comfortable on the command line) to glean outgoing trunk info from your box is to run:
grep OUT_ /etc/asterisk/extensions_additional.conf | grep -v exten
cool
Cool, thanks. I got teleyapper installed ... can you initiate the calls, though, through the FreePBX gui? I want to be able to send out a call to multiple phones without having to pick up my phone and dial 674, type my password, and record a message. I want to be able to, for example, type my message (which will be converted to speech with Cepstral), and tell the system who all I want it to call ... and when. Any advice?
I'm actually building that functionality into a product for a customer right now. So there will probably be a new, improved product that does this and much more down the road. :wink5:
cool Ward!
Awesome - please keep me posted on this!
As a side note. When I dial 674 and try to send a message to a group (TeleYapper group), it says that it is successful in setting it up, but the call never goes out. Not sure what I've misconfigured at this point.
Have you done all the article said, like using phpAdmin to setup call data in the table? Seen debug of the app? Seen what happens when it's run in /var/log/asterisk/full ? Permissions are all correct?
I have no need to blast messages so haven't set this up. Someone else may be helpful here.
thanks
I'll look further into this soon. I have another high priority project I'm on.
