Spoofed caller ID - possible SIP hack attempt?
gaijin
Hi, some of my customers are reporting "prank calls" from MeucciSolutions.
I have investigated and a simple google search reveals that this is a fairly common thing.
Has anyone else in the PIAF community had this?
The IP that sent the SIP attack is 93.190.143.10. and I have since blocked this at the firewall for affected customers.
I am not too stressed about it because I have always used secure passwords and very few SIP extensions that are permitted externally on my customer's boxes. And I am slowly getting rid of SIP trunks (removing the need for anon inbound SIP) and moving to IAX where possible. The customers that reported this are ones that I have allowed a anycid/anydid inbound route. (I have since found & implimented a workaround for the original reason I had this route in the first place)
My questions are:
1: Is there any form of common list, a bit like an SMTP RBL, for dodgy SIP hackers?
2: What could the hackers possibly achieve through this kind of port scanning? (are they simply just looking for IPs that respond on port 5060 to target later for a more targeted hacking attempt?)
3: Can I put a dyndns address (FQDN) in the permit field? I have some customers that wish to use remote SIP extensions from thier non static connections.
4: How hard would it be for some guru to write a macro that would "honeypot" an anycid/anydid attempt that then write that IP to a fail2ban, IP table rule or similar?
I received 8 SIP calls today from -
"MeucciSolutions" - SIP/93.190.143.10-b770b820.
They were all disconnected in 17 seconds or less. I haven't had the time to look at my logs yet.
We got the calls as well. The price you pay for opening the SIP port. All the creep got was Congestion, but I agree. There's got to be a better way. Seems that some of the greenies didn't fare as well.
It's a bit frustrating... These attacks will over time get more and more sophisticated.
It seems as though however easy it is to setup a VOIP server right now... In the future it will be a hell of a lot cheaper to get an expert in to do this... (as long as they get it right)...
Adding the following line to /etc/sysconfig/iptables above the last COMMIT line will get rid of the creep:
-A INPUT -s 93.190.143.10 -j DROP
Then... service iptables restart
Good idea. I'll skip adding it to the TO-DO pile. :cool: We should be able to just add another Fail2Ban rule to search for these in the Asterisk log...
[May 13 18:53:57] VERBOSE[6620] logger.c: -- <SIP/93.190.143.10-b7df57d8> Playing 'ss-noservice' (language 'en')
Should look something like this:
VERBOSE.* logger.c: -- .*IP/<HOST>-.* Playing 'ss-noservice' (language '.*')
And it goes in the failregex section as a new line in /etc/fail2ban/filter.d/asterisk.conf. Anyone want to test it and report back? Don't forget to restart Fail2Ban: service fail2ban restart
As always, you are the man!
I will check on my lab server (1.5 Beta) tonight and report!
Don't know what everyone else is seeing but I'm not getting pinged all that often. Every 15 minutes or so. The default fail2ban jail setting in /etc/fail2ban/jail.conf requires three fails in 10 or 15 minutes. You'll need to change findtime (and probably bantime) to address this.
Why not just go to SSL with pre shared key and certificate its going to have to happen eventually
Wouldn't this be a case where disallowing anonymous SIP calls would at least prevent the phones from ringing? Leaving fail2ban to catch the password attacks.
It's amazing how many people this IP/group has affected, including those with ATA's, not just SIP PBX's. Right now all my working installs are IAX and I haven't seen this. But I'll have to look at the Pfsense logs to see who's been knocking on SIP ports.
RandomPerson
