Magic Jack issues
thanks for all the help last night...
trying to just disable the trunk that was working and re-enable the trunk that was not.
I also tried on a different proxy as well
tonight i might vpn into work when nobody is there (using the trunk) and disable mj2 trunk and try setting it up at home to see if it will register.
I need to get another for a 3rd box at another location about 3.5 hrs away....
Will post results after I get home.
Myk
Ok, I have two different MJ accounts/proxies and both are registered
Host                            Username       Refresh State                Reg.Time
proxy01.xxxxxxx.talk4free.com:  Exxxxxxxxxx0       105 Registered           Wed, 26 Aug 2009 00:35:39
proxy01.xxxxxxxxxxxx.talk4free  Exxxxxxxxxx0       105 Registered           Wed, 26 Aug 2009 00:35:39
So all I can say is make sure your trunks are EXACTLY the same except for the account, password and proxie
Myk
Myk
Congrats! Thanks for taking the time to test it. I am still chasing my self induced problems here and just about ready to do a fresh install.
you could prob use the same proxy, as two indv MJ dongles plugged in I would assume would pick the same proxy, just use different account #/passwords
Myk
mine did work. sorry been so busy with work forgot to post. it was..lets say...a typographical error... :D
