Solved-Problems with Vitelity, now other questions
*This is solved, but I have questions on post 15.
I screwed up my previous post, so this one is probably going to be short. I've learned (hopefully) a lot on this forum and nerdvittles.
I'm able to make phone calls, but unable to receive. I get a busy tone when trying. I get the standard email from vitelity, saying the server isn't registered.
According to Vitelity: Your current default routing method is set to a SIP server or SIP extension gateway device.
I've checked through the forums, and checked my firewall to verify that my ports are forwarded correctly, 5004-5084 (udp) are forwarded to my pbiaf machine, as well as 10000-20000(udp).
I'm quite stuck, as this has worked previously. The only thing that I changed between when it worked and when it didn't was changing the dialout pattern attempting to make the dialout process faster. Please help. Thanks.
The inbound settings are:
The register string has my [email protected].
Edit: Fixed in post 12.
type=friend
dtmfmode=auto
username=bmanderso
secret=
context=from-trunk
insecure=very
canreinvite=no
host=inbound22.vitelity.net:5060
