I just installed a PIAF with a TE110P T1 card. Inbound calls to the T1 run a custom context where I send the call to out a SIP trunk.
This will work fine for a while. Then, out of the blue, I will dial in and get fast busy.
When I connect via ssh to asterisk, it indicates the T1 is OK. However, a zap show channels shows a "stuck" call on one of the channels. There really isn't a call. I also notice that I can't connect using FreePBX web app. Also, when I'm in the CLI, I cannot stop or shutdown asterisk.
In order to clear this up, I have to kill the asterisk process, then unload zaptel, reload zaptel, then restart asterisk.
Anyone with ideas? Right now I'm having to check every hour to make sure this is working...
