madberry
- Oct 25, 2009
- 31
- 0
I followed this post to be particular: http://pbxinaflash.com/forum/showpost.php?p=36099&postcount=17
Here is the output when I click Test All Schemes and enter the number in the debug
Send to XBMC: http://xbmc.local:2345
Returned Result would be: Chase Florell (Mobile)
resulttook 0.0420 seconds.![]()
Works Like a charm. Just one request could we get the option to either add or remove displaying the name as well?
Thanks,
In that case you have a proper XBMC display?
When you enter the http string, you should have
Chase Florell (Mobile)as a result.
The http string should be the address of your callerid.php in the superfecta module folder, and add at the end a ?thenumber=1403xxxxxxx
What do you mean? You want to display one line only with just the number? Not the name? Or just the name and not the number?
Please answer all questions, if not we will spend hours trying to understand your problem.
In the superfecta page:
- enter the complete number (including the leading 1)
- check the 'test all cid'
- click debug.
Do you have a correct XBMC display Yes or No?
Yes. I already answered that question (twice).
[Thu Nov 05 20:38:30 2009] [error] [client 10.10.10.10] PHP Notice: Use of undefined constant username - assumed 'username' in /var/www/html/admin/modules/superfecta/bin/source-AsteriDex.php on line 18, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:30 2009] [error] [client 10.10.10.10] PHP Notice: Use of undefined constant password - assumed 'password' in /var/www/html/admin/modules/superfecta/bin/source-AsteriDex.php on line 21, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:34 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Asterisk_Phonebook in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:34 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_White_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:34 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 61, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:34 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 136, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:35 2009] [error] [client 10.10.10.10] PHP Notice: Undefined offset: 1 in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 158, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:35 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Yellow_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:36 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Telco_Data in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:50 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Asterisk_Phonebook in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:50 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_White_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:50 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 61, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:50 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 136, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:51 2009] [error] [client 10.10.10.10] PHP Notice: Undefined offset: 1 in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 158, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:51 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Yellow_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:51 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Telco_Data in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:38:59 2009] [error] [client 10.10.10.10] File does not exist: /var/www/html/admin/images/logo.png, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:15 2009] [error] [client 127.0.0.1] PHP Notice: Undefined index: Default_Asterisk_Phonebook in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239
[Thu Nov 05 20:39:29 2009] [error] [client 10.10.10.10] File does not exist: /var/www/html/admin/images/logo.png, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:30 2009] [error] [client 10.10.10.10] PHP Notice: Use of undefined constant hostspec - assumed 'hostspec' in /var/www/html/admin/modules/superfecta/bin/source-AsteriDex.php on line 12, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:30 2009] [error] [client 10.10.10.10] PHP Notice: Use of undefined constant username - assumed 'username' in /var/www/html/admin/modules/superfecta/bin/source-AsteriDex.php on line 18, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:30 2009] [error] [client 10.10.10.10] PHP Notice: Use of undefined constant password - assumed 'password' in /var/www/html/admin/modules/superfecta/bin/source-AsteriDex.php on line 21, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:40 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Asterisk_Phonebook in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:40 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_White_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:40 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 61, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:40 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 136, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:40 2009] [error] [client 10.10.10.10] PHP Notice: Undefined offset: 1 in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 158, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:40 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Yellow_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 20:39:41 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Telco_Data in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
You did not specified if you had it with the checkbox checked. Now it's clear.
Could you look in the different logs in var/log/httpd/ to look at the different requests and possibly error with the two following scenarii:
- the debug scenario (check all cid, number, debug)
- the http line discussed previously
There is a lot of this in the error log
192.168.0.102 - maint [31/Oct/2009:23:44:32 -0600] "GET /admin/modules/superfecta/bin/callerid.php?thenumber=1403??????? HTTP/1.1" 200 15 "-" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:18 -0600] "GET /admin/config.php?type=setup&display=cidlookup HTTP/1.1" 200 16883 "http://pbx.mydomain.com:82/admin/config.php?display=did&extdisplay=17772891940%2F&extension=17772891940&cidnum=" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:18 -0600] "GET /admin/images/logo.png HTTP/1.1" 404 300 "http://pbx.mydomain.com:82/admin/config.php?type=setup&display=cidlookup" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:18 -0600] "GET /admin/images/ HTTP/1.1" 200 15567 "http://pbx.mydomain.com:82/admin/config.php?type=setup&display=cidlookup" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:20 -0600] "GET /admin/config.php?display=cidlookup&itemid=5 HTTP/1.1" 200 16951 "http://pbx.mydomain.com:82/admin/config.php?type=setup&display=cidlookup" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:20 -0600] "GET /admin/images/logo.png HTTP/1.1" 404 300 "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:20 -0600] "GET /admin/images/ HTTP/1.1" 200 15567 "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:28 -0600] "POST /admin/config.php?display=cidlookup&itemid=5 HTTP/1.1" 302 - "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:29 -0600] "GET /admin/config.php?display=cidlookup&itemid=5 HTTP/1.1" 200 21763 "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:29 -0600] "GET /admin/images/logo.png HTTP/1.1" 404 300 "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:29 -0600] "GET /admin/images/ HTTP/1.1" 200 15567 "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
10.10.10.10 - maint [31/Oct/2009:23:45:34 -0600] "POST /admin/config.php HTTP/1.1" 200 1078 "http://pbx.mydomain.com:82/admin/config.php?display=cidlookup&itemid=5" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.1.4) Gecko/20091016 Firefox/3.5.4"
127.0.0.1 - maint [31/Oct/2009:23:45:52 -0600] "GET /admin/modules/superfecta/bin/callerid.php?thenumber=1403??????? HTTP/1.1" 200 15 "-" "asterisk-libcurl-agent/1.0"
[Thu Nov 05 21:20:42 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Asterisk_Phonebook in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:20:42 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_White_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:20:42 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 61, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:20:42 2009] [error] [client 10.10.10.10] PHP Notice: Undefined variable: number_error in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 136, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:20:43 2009] [error] [client 10.10.10.10] PHP Notice: Undefined offset: 1 in /var/www/html/admin/modules/superfecta/bin/source-White_Pages.php on line 158, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:20:43 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Yellow_Pages in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:20:43 2009] [error] [client 10.10.10.10] PHP Notice: Undefined index: Default_Telco_Data in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239, referer: http://pbx.mydomain.com:82/admin/config.php?display=superfecta&scheme=base_Default
[Thu Nov 05 21:23:30 2009] [error] [client 127.0.0.1] PHP Notice: Undefined index: Default_Asterisk_Phonebook in /var/www/html/admin/modules/superfecta/bin/callerid.php on line 239
I look at mu error logs every other day or so. I've seen that no index on line 239 as well.
I removed all of the older ways of getting this to work. That is when it stopped working.
I now get the same symptoms as above. Works fine in debug. But when some one calls nothing shows up in Boxee.
Which makes me ask this question: Are we sure it reaches the XBMC source? Superfecta is after al designed to stop after it finds the CID info.
O and my setup is using port 80.
Live Chat
Video Conferencing
Check your inbox!
