Help on contexts on where to place system call in extensions_custom.conf?
crashtestdummy
Hello there,
I am attempting to follow either http://www.mythdora.com/?q=node/5001 or http://www.voip-info.org/wiki/view/Asterisk+config+extensions.conf to pass caller id information to xyac running on another system.
Following http://www.voip-info.org/wiki/view/Asterisk+tips+MythTV+integration seems to imply that one way to accomplish my goal is to get PIAF to issue a system call when someone dials my one extension in my simple home PIAF environment. The example given is:
exten => s,1,System(/bin/echo -n -e "'@CALL${CALLERIDNAME} ~${CALLERIDNUM}'" | nc -w 1 192.168.1.200 10629)
My basic question is where to place this. I assume this would be a manual entry in extensions_custom.conf, but I am unsure of the context ([????]) where it should go. Any thoughts on this? Since the priority is 1, I assume this line has to be the first line in the context, right?
http://www.mythdora.com/?q=node/5001 has a more complex solution which did not work for me. Looking at the /var/log/asterisk/full log file, I could not see the issue, but I am new to asterisk.
I have xyac installed on my other system, and a test command such as “echo -n -e "test" | nc -w 1 192.168.1.200 10629” works, so I know that I do not have any firewall or target machine issues.
Thanks for your help or pointers.
Mike
If you want this to happen on inbound calls, I would put this in
[from-pstn-custom]
You will have to create this context in extensions_custom.conf. Inbound calls on PIAF are usually in either the from-trunk or from-pstn context. The from-trunk context simply points to from-pstn. The first line in from-pstn is an include=>from-pstn-custom.
If Asterisk finds from-pstn-custom in extensions_custom.conf, it will process the code there first, then off to the rest of from-pstn.
Hello there,
Mike
Mike;
The caller ID superfecta now has a YAC output source - you might consider looking into it.
Solved
Thanks for the help.
I was able to solve this by figuring out two items.
The instructions at http://www.mythdora.com/?q=node/5001 forgot to add the (send) label to the system call line. I added a post to that page to highlight this.
Also, the instructions to use "amportal restart" did not appear to cause my system to read in my config file changes. That was a revelation which allowed me to actually debug the code lines.
Mike
