Turn off strong password for extension
mrandle
I have a situation where PIAF 1.4 is installed on a site and they do not want to use the strong password i.e 6 characters with at least 2 of them being a-z.
i have found in the file /var/www/html/admin/common/script.js.php where the weak password is detected, what is the modification to this file that is needed to allow for weak password.
This PIAF does not connect to the public internet so extension security is not an issue.
Mark
Disable the module in FreePBX Module Admin... understanding this is a very dumb thing to do. :wink5:
Once that a phone is configured and working, why would anyone need to go near the password, let alone know it?
Voicemail does not use same password that one uses as a secret to connect a SIP device.
Yes, your right, voicemail has a separate password. Then there is no reason to not have a strong SIP secret. It would be foolish not to.
