php broken?
Dale Fredrikson
Hi. When I go to phpMyAdmin in FreePBX, here's what I see:
phpMyAdmin - Error
Cannot start session without errors, please check errors given in your PHP and/or webserver log file and configure your PHP installation properly.
Any ideas?
Regards,
Dale
I had a PHP error once. It said: phpMyAdmin tried to connect to the MySQL server, and the server rejected the connection. You should check the host, username and password in your configuration and make sure that they correspond to the information given by the administrator of the MySQL server.
Error
MySQL said:
#1045 - Access denied for user 'root'@'localhost' (using password: YES)
SOLUTION:
To change the password in phpmyadmin, find the line: -
$cfg['Servers'][$i]['password'] = 'passw0rd';
in /var/www/html/maint/phpMyAdmin/config.inc.php
and change it to what ever you set you MySQL root password to.
Then run the mysql_install_db script.
Have you updated anything recently.
Try
chown -R asterisk:asterisk /var/lib/php/session
