IP-PBX Build
Milliwatt
Hi all. I've finally decided on an IP-PBX build configuration. The components (minus Google phone) listed at the following site -
http://www.legitreviews.com/article/1058/2/
look good spec wise so this is where I'm starting. The ultimate configuration calls for two remote trunks from two remote cities via CallCentric. These two trunks need to be answered from any of three phones so I guess three line phones are in order. I'm interested in VOIP phones that are known to work good with Asterisk & PiaF. PiaF pushes Aastra but they are pretty expensive. Any suggestions would be more than welcome.
I also need to connect to three remote (300 feet) analog devices using an ATA adapter box. The ones I've looked at -
http://www.888voipstore.com/single-fxs-adapters/
all seem fairly reasonable but again I'm looking for an adapter known to be compatible with Asterisk & PiaF. Suggestions here also would be most welcome.
Thanks in advance for any information.
Linksys PAP2T. 2 FXS ports per device. About £40 this side of the pond so probably even cheaper in the USA.
It should work straight out of the box on a PIAF build (all I do with mine is change the progress tones to the British ones, and adjust the timer so RECALL button (what we have instead of hookflash) works correctly.
