Flash Operator Panel not updating?
blanchae
The FreePBX status shows that FOP is green. When I go to FOP, it shows all the extensions, parking lots and trunks as it should but nothing happens when a call is made from one extension to another. Doesn't show ringing or that an extension is in use. Don't really know where to look...:banghead:
I'm using the following:
PBX in a Flash Version 1.3 Daemon Status
* Asterisk * ONLINE * Dahdi * ONLINE * MySQL * ONLINE *
* SSH * ONLINE * Apache * ONLINE * Iptables * ONLINE *
* Fail2ban * ONLINE * IP Connect* OFFLINE * Ip6tables * ONLINE *
* BlueTooth * ONLINE * Hidd * ONLINE * NTPD * ONLINE *
* Sendmail * ONLINE * Samba * OFFLINE * Webmin * ONLINE *
* Ethernet0 * ONLINE * Ethernet1 * ONLINE * Wlan0 * N/A *
* Running Asterisk Version : Asterisk 1.6.0.6
* Asterisk Source Version : 1.6.0.6
* Dahdi Source Version : 2.1.0.4+2.1.0.2
* Libpri Source Version : 1.4.9
* Addons Source Version : 1.6.0.1
DeltaForeignCO.Force on 192.168.203.254 - eth0
CentOS release 5.2 (Final) :32 Bit Kernel: 2.6.18-92.1.6.el5
In /var/www/html/panel/
I changed:
manager_user=admin
manager_secret=xxxxxxx
to match /etc/asterisk/manager.conf
What should poll_interval=120 be set to? 120 seconds?
Things are appearing to work but incredibly slow on updating, I hang up the phone and it still shows that it is in use 5 min later...
I changed:
manager_user=admin
Strange. Is this a test machine or a production machine?
Test machine. The extensions show up on the left hand side but there's no indication that anything is active. I have two SIP phones and they show up as trunks on the right hand side. Haven't found a decent tutorial on how to use FOP so I don't know how it's supposed to work.
The installed default FOP is version 0.27, for Asterisk 1.6, you require version 0.30. It is NOT a trivial upgrade as version 0.30 has split the configuration into two directories: one client directory in /var/www/html/panel (as previous versions) and a new server directory /usr/local/fop2. FOP integrates with FreePBX, astb and apache so you have to get all 4 services talking.
Rather than upgrade to FOP v 0.30 which is at its end of life. I recommend upgrading to FOP2 which would take about the same amount of effort.
