Hey all,
Firstly PBX in a Flash Version 1.4 is what Im running at the moment. I have a user who has his own phone line from vitelity with a trunk setup to ring direct to his extension. Whenever he answers calls on this line the call doesnt connect. Other trunks are functioning fine with IVR's on same server. I pulled the log from when this was happening, he is extension 2001 in the logs.
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-exten-vm:8] Macro("SIP/#######-#######", "record-enable|2001|IN") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-record-enable:1] GotoIf("SIP/#######-#######", "1?check") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Goto (macro-record-enable,s,4)
[2010-05-26 17:13:58] DEBUG[11552] app_macro.c: Executed application: GotoIf
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-record-enable:4] AGI("SIP/#######-#######", "recordingcheck|20100526-171358|1274919238.4862") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: recordingcheck|20100526-171358|1274919238.4862: Inbound recording not enabled
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- AGI Script recordingcheck completed, returning 0
[2010-05-26 17:13:58] DEBUG[11552] app_macro.c: Executed application: AGI
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-record-enable:5] MacroExit("SIP/#######-#######", "") in new stack
[2010-05-26 17:13:58] DEBUG[11552] app_macro.c: Executed application: Macro
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-exten-vm:9] Macro("SIP/#######-#######", "dial|15|tr|2001") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-dial:1] GotoIf("SIP/#######-#######", "1?dial") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Goto (macro-dial,s,3)
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-dial:3] AGI("SIP/#######-#######", "dialparties.agi") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Launched AGI Script /var/lib/asterisk/agi-bin/dialparties.agi
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: dialparties.agi: Starting New Dialparties.agi
[2010-05-26 17:13:58] VERBOSE[11555] logger.c: == Parsing '/etc/asterisk/manager.conf': [2010-05-26 17:13:58] VERBOSE[11555] logger.c: Found
[2010-05-26 17:13:58] VERBOSE[11555] logger.c: == Parsing '/etc/asterisk/manager_additional.conf': [2010-05-26 17:13:58] VERBOSE[11555] logger.c: Found
[2010-05-26 17:13:58] VERBOSE[11555] logger.c: == Parsing '/etc/asterisk/manager_custom.conf': [2010-05-26 17:13:58] VERBOSE[11555] logger.c: Found
[2010-05-26 17:13:58] VERBOSE[11555] logger.c: == Manager 'admin' logged on from 127.0.0.1
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: dialparties.agi: Caller ID name is 'Bill Elswick3103728624' number is '3103728624'
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: dialparties.agi: USE_CONFIRMATION: 'FALSE'
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: dialparties.agi: RINGGROUP_INDEX: ''
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: dialparties.agi: Methodology of ring is 'none'
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- dialparties.agi: Added extension 2001 to extension map
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: > dialparties.agi: Extension 2001 has call screening off
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- dialparties.agi: Extension 2001 cf is disabled
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- dialparties.agi: Extension 2001 do not disturb is disabled
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: > dialparties.agi: extnum 2001 has: cw: 1; hascfb: 0 [] hascfu: 0 []
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: dialparties.agi: ExtensionState: 0
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- dialparties.agi: dbset CALLTRACE/2001 to 3103728624
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- dialparties.agi: Filtered ARG3: 2001
[2010-05-26 17:13:58] VERBOSE[11555] logger.c: == Manager 'admin' logged off from 127.0.0.1
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- AGI Script dialparties.agi completed, returning 0
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Executing [s@macro-dial:7] Dial("SIP/#######-#######", "SIP/2001|15|tr") in new stack
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- Called 2001
[2010-05-26 17:13:58] VERBOSE[11552] logger.c: -- SIP/2001-0923db10 is ringing
[2010-05-26 17:14:07] VERBOSE[11552] logger.c: -- SIP/2001-0923db10 answered SIP/#######-#######
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: == Spawn extension (macro-dial, s, 7) exited non-zero on 'SIP/#######-#######' in macro 'dial'
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: == Spawn extension (macro-dial, s, 7) exited non-zero on 'SIP/#######-#######' in macro 'exten-vm'
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Executing [h@macro-dial:1] Macro("SIP/#######-#######", "hangupcall") in new stack
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/#######-#######", "1?skiprg") in new stack
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Goto (macro-hangupcall,s,4)
[2010-05-26 17:14:18] DEBUG[11552] app_macro.c: Executed application: GotoIf
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Executing [s@macro-hangupcall:4] GotoIf("SIP/#######-#######", "1?skipblkvm") in new stack
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Goto (macro-hangupcall,s,7)
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Executing [s@macro-hangupcall:7] GotoIf("SIP/#######-#######", "1?theend") in new stack
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Goto (macro-hangupcall,s,9)
[2010-05-26 17:14:18] VERBOSE[11552] logger.c: -- Executing [s@macro-hangupcall:9] Hangup("SIP/#######-#######", "") in new stack
He's an important user in the company, and i need to resolve this immediately. Ill be putting a call into Vitelity to see if there has been any outages, as well as check his trunk config. ANY help would be hugely appreciated!
Thanks,
Derrick
Thanks,
Derrick
