Re: Vcalloway
Just read your traces, it is interesting to see that dialing vmail is not processed within the from-internal-additional context, Asterisk is dialing out on a trunk.
Did you modify something in the dialplan? Are you using a special context for your extensions?
Did you install ALL the freePBX modules as requested in the documentation? Did you pass the "check_install" tool?
You should get this
Anyway, I will make some tests with the same version to debug.
Will keep you posted.
Regards
aastra1
You should get this
-- Executing [vmail@from-internal:1] Answer("SIP/2500-00000085", "") in new stack
-- Executing [vmail@from-internal:2] AGI("SIP/2500-00000085", "aastra-vm.php") in new stack
-- Launched AGI Script /var/lib/asterisk/agi-bin/aastra-vm.php
Regards
aastra1
