PIAF 1.7.5.5 Now Available
wardmundy
Nerd Uno
With a little luck, we'll have the newest releases of PBX in a Flash available for download from SourceForge later tonight. Both 32-bit and 64-bit versions will be available. Documentation is available NOW in the Docs tab of pbxinaflash.com and pbxinaflash.net. THANKS, TOM!!!!
It's Not Baskin Robbins, but...
PIAF 1.7.5.5 is now available and comes in six flavors, all with CentOS 5.5 and FreePBX 2.6.
The SourceForge links are below. You choose Gold, Silver, or Bronze after the CentOS 5.5 install from the ISO completes.
32-bit:
GOLD - Asterisk 1.4.21.2 + Zaptel
SILVER - Asterisk 1.4.32 + Dahdi
BRONZE - Asterisk 1.6.2.8 + Dahdi
64-bit:
Torrents
available here:
PIAF 1.7.5.5 - 32 bit
PIAF 1.7.5.5 - 64 bit
Install documentation in PDF format is available here or here.
Complete tutorial: knol.pbxinaflash.com
Enjoy!
Gold, Silver, and Bronze sounds like there are monies associated (..in the future?). Are these names meant to suggest some form of remuneration is in store?
thx
PP
thx
PP
It's open source. Always will be.
32-bit:
64-bit:
Torrents
available here:
Enjoy!
My guess is you are trying to use the 32 bit net install right? I found a typo which reversed the path.
you should be able to download it by hand
wget http://www.pbxinaflash.net/1755/files/piafdl.gz
will fix the ISO and send out some new ones with the correct path. Seems to only affect the 32 bit version at the moment.
Thanks for the bug report. I am recompiling the ISO as we speak.
Thanks for the info. I did try the .net last night but I guess I didn't try hard enough. I have 1.7.5.5 running on OpenVZ now.:cool:
Just out of curiosity, how has Solus worked for you? The pricing is great compared to others, and alot cleaner/simpler... has it met all of your needs?
It's getting there. I'd like to see a few more things added but I'm sure they will eventually. It's the best alternative with the most potential IMHO.
Thanx for your thoughts, it's a good reaffirmation... the cleanliness of the interface and price really appeals to me (I like the lack of needless complexity). I'm heading down this same road of virtual offerings (just starting out) & always appreciated your powerpbx site and writeups; just wanted to say thanks :)
