Hi there,I was able to correct the display issue by reapplying the 2.6 firmware rpm and restarting my phones.
Hi,
Bit of an Aastra XML noob, so apologies if the question is a bit obvious
I am planning to upgrade the XML scripts for a customer in the very near future. I'm comfortable with the process described above, but you don't say what the user will experience on the handset after the process is complete? Will the handset retain the existing login information or will they have to enter their ext & vmail pwd again? I'm presuming that the mac.cfg files will remain and that the phones will log in automatically, but I'd rather know for sure so that when I do the update remotely I can prepare the customer for any required actions on their part.
Thanks for your help,
Colman
I updated to beta 6, but now the park button is missing from the bottom.
Any clue where it is?
aastra1,
I upgraded to the latest firmware and b6 of the scripts. Completely uninstalled b5 like the instructions say. Under b5 the only problem I had was the DND problem like others, where the DND button and display state were never updated, however DND was toggled when you pressed the button. Well, b6 seems to have fixed that problem completely, at least for mo. However, now my call fwd does not function properly. After the upgrade my Call Fwd button on the phone (57i) came on and permanently stays lit and says CFWD activated on the screen. It is NOT actually activated and if I press the Call Fwd button it says on the Call forward for 701 then below it says Call Forward is currently deactivated and I have button options at the bottom for Acivate, My Numbers and Exit. Any idea why this is happening even thought it is telling me call fwd IS deactivated? I get inbound calls fine. Like I said, this is the first time I ever had this problem, after I installed b6.
aastra1,
Ok, here is the info you asked for.
Asterisk - 1.4.21
FreePBX - 2.8.0rc1.3
Firmware on 57i - 2.6.0.66
Now, I happened to find what's causing the problem by accident. I reset the phone to factory defaults to clear the config and restarted. It pulled the config from my pbx no problem, started up and the CFWD problem was gone! HOWEVER (always a damn gotcha), when I assigned a second line on the phone to register to my dev box (same asterisk and fpbx versions, but diff ext number) and restarted the phone the problem was back, exactly like I explained in my first post. To confirm I restarted the phone again, no change. Then I removed the reg to the dev box, restarted again, and voila, problem gone again. I tried this 3 times just to verify. Restarting the pbx makes no difference either. So it seems like the script is being weird when it is registered to more than one server. I don't remember this being a problem in the past and I normally have 2 lines registered to the different boxes. Any ideas? Has anyone else in the forum tried this, or can confirm I'm not the only one seeing this? Thanks.
# Action URI
action uri registered: http://$$AA_XML_SERVER_AA$$/$$AA_XMLDIRECTORY_AA$$/asterisk/sync.php?action=register&user=$$SIPUSERNAME$$
# Action URI
action uri registered: http://$$AA_XML_SERVER_AA$$/$$AA_XMLDIRECTORY_AA$$/asterisk/sync.php?action=register&user=[COLOR=red]$$AA_[/COLOR]SIPUSERNAME[COLOR=red]_AA[/COLOR]$$
action uri poll:http://$$AA_XML_SERVER_AA$$/$$AA_XMLDIRECTORY_AA$$/asterisk/sync.php?action=check&user=$$SIPUSERNAME$$
action uri poll:http://$$AA_XML_SERVER_AA$$/$$AA_XMLDIRECTORY_AA$$/asterisk/sync.php?action=check&user=$$[COLOR=red]AA_[/COLOR]SIPUSERNAME[COLOR=red]_AA[/COLOR]$$
Thanks for the info aastra1. I understand the reasoning behind the scripts only working on one line. I wasn't looking to use them on the dev box, it was just a simple reg so I can do testing on it. If I recall correctly, in my old config I used the same ext. number on both pbx's so perhaps thats why I never say an error? Either way I'll try one of the changes you suggest. Like I said, I want the full functionality of the scripts on my prod box, so I don't want to hose that up.Worst case I can try digging out one of my old phones to use on the dev machine. Thanks for your help, and of course the great scripts. I love the 57i and these make it even better!
aastra1,
Any chance these scripts could at some point include Aastra Mobile Client (AMC) functionality (like MX-One) so iphone's and or android phone could be used with Aastra's Mobile App and Asterisk-PIAF?
Hi I have some 480i phones and am wondering what avahi is being used for. I guess from reading that it does not work on these older phones. Is it just the initial discovery? That works fine with dhcp option 66. Do mDNS and avahi provide other features?
The reason I ask is that the version of mDNSResonder in your ftp is causing dependency problems with the latest version of avahi from centos.
Unfortunately the focus has been more on PIAF and another one starting with a T as we were in a beta phase for the scripts. It is a lot of work to monitor multple forums.PS: Are you still checking Elastix forums?
GoodOK, carried out the upgrade and all the phones restarted correctly, and the CFWD & AWAY functionality has been restored.
This is not an issue, if you read the documentation you will understand that even in extensions mode the scripts provide a login/logout (hot desking) capability this is why you have a logout button in the profile. If you don;t want it just modify the default template (demo-user.prf) and replace the logout button with something else.Couple of issues:
1. Despite not being a device&user setup, the first soft key on the 6731i's is the login/logout function.
Feels like a bug but based on the trace involving outgoing.php the error should be when a phone dials out not when you hang up. Can you give us more details on your platform, Asterisk version, freePBX version... and also dos it happen for every call or just specific calls such as external calls, also have you enabled the external number lookup? Anything would help us to understand. Also we assume you are using Beta6 right?2. After a call finishes, the display reads 'Cannot display'. looking in the Apache error log I see "[Tue Jul 13 13:43:49 2010] [error] [client 192.168.0.63] PHP Fatal error: Call to a member function output() on a non-object in /var/www/html/aastra/asterisk/outgoing.php on line 301" Any ideas?
That's kind of what I thought. But you are right it will cause problems for old phones if you don't have a good dhcp server. Not sure if this would help make things more compatable for older phones or not. http://linux.die.net/man/8/avahi-dnsconfd my dhcp works fine. Maybe when things settle down you can look at it.
Good
Live Chat
Video Conferencing
Check your inbox!
