PIAF Hardware Recommendation
atsak
Trying to think what's best; can anyone recommend a system with a PCI-e slot or two (need 8 FXO ports so will need somewhere to put those) that's still relatively compact? Two power supplies would be a plus.
I'd actually prefer not rack mountable for this particular application.
Prefer something that might work in PBXIAF without fiddling with network card drivers.
I would use an Intel D945GCLF2 motherboard in a Jetway JC-114 case. The motherboard has one PCI slot (not PCI-e) and the case has two slots. You can put a Sangoma A200 with one Remora and get 8-FXO ports. The box is about 14 inches square and about 1.5 inches thick. It is wall mountable.
I would go with the newer Intel D510MO http://www.intel.com/products/desktop/motherboards/D510MO/D510MO-overview.htm
Slightly lower power usage, and more memory capacity, plus both a PCI and PCI-e mini slot.
You might also like the BGears cases http://www.bgears.com/b-envi.html
Both are readily available on Amazon and eBay.
Dreamwave has an 8 port FXO/FXS (you pick how many of which) PCI card at a good price that fits in a single slot.
http://dreamwave.net/products/pbx-hardware/tdm800-8-port-fxo-fxs-pci-card
It looks like Newegg.ca (Canadian version) has some of these cases with motherboards included. Now I just have to figure out which motherboard matches up with what you suggested; I think it's this one http://www.newegg.ca/Product/Product.aspx?Item=N82E16856107043&cm_re=Jetway-_-56-107-043-_-Product. I will be using a Sangoma card. They seem to just work (limited experience so far).
da1Bear's suggestion is good too but I am having trouble finding that in Canada.
