why not post them to google docs and use the piaf script donated to pull them down from the CLI?
Then you dont have to depend on someone else to host them?
I feel the better solution, as there are some PiaF specific elements here, that the files be hosted on PiaF.
true, but its been 11 days since you sent in the files and they are still nowhere to be found :(
@jroper: Since its been two weeks, I can host the files for you on my web server without any problems until Ward gets around to it. I actually need the files myself so I'm happy to share with others. Let me know and I can send you details.
Script has a new Home
Joe Roper has opened a new Project at the Development Support Site for this script, and its ongoing maintenance and developement. The Project can be found here.
The Main script can be pulled directly from the SVN by all without authentication.
This link should generally point to the current version of the main script file.
The most current version of the Fax Icon can be similarly accessed here:
These two products together are an awesome system - imagine what a little time with some of the generously spirited coders here amoung us may add to and improve on? Join in and lets find out.
Note, I have made some simple changes, e.g. to install the later version of avantfax, and drawing down the files from source, but I have not got round to actually testing it all in one go, so test systems only please until I get a look at it, or someone else confirms it's OK.
This link should generlly point to the current version of the main script file.
These two products together are an awesome system - imagine what a little time with some of the generously spirited coders here amoung us may add to and imrpvoe on? Join in and lets find out.
Above links are incorrect :(
The forum condenses them, hiding the actual link dest... I cant figure out how to make it stop doing that. Copy the underlying links.
extraction of avantfax-3.3.2.tar.gz fails because its a .tgz file...
also the rh-install is installing avantfax into /var/www instead of /var/www/html
Your right - its seems to be requiring authentication at my links. Ill fix it shortly.
am also finding the .sh file at: http://projects.colsolgrp.net/attachments/download/339/a-fax.sh and still not in the above links that have 'raw' in them....?
This has been corrected - and the links work as they should now. These links generally allways point to the most current version of the script. If you want previous version, they are also available through the web interface.
Script:
[URL]http://projects.colsolgrp.net/projects/afax/repository/raw/a-fax.sh[/URL]
Icon:
[URL]http://projects.colsolgrp.net/projects/afax/repository/raw/ico_fax.png[/URL]
The Project Wiki is avalable HERE.
I had to include in iax_custom.conf
calltokenoptional = 127.0.0.1/255.255.255.0
Good point
Anyone remember what the version change was that required this?
Can the script be used to update and earlier installation of Hylafax/Avantfax? I am sure there are risks, but are there any apparent issues?
No, don't do it. You will duplicate all sorts of things.
Just upgrade avantfax only.
