I have 3 extentions connected to a working incredible 1.8.1. 2 extentions are "local" to the asterisk box and are constantly unregistering. My third extention (a remote extention) is always registered with no problems. For example I can click register on both phones and they will show fine with a 11ms ping time for about 30 seconds. One or the other ( or both) extention will constantly change to unreachable in sip info in freepbx. My logs are filled with unregistering registering etc etc all day night. Asterisk box is directly on internet with all ports available to it with a static ip.
PBX in a Flash PURPLE Daemon Status - Version 1.7.9 Released on 110910
┌────────────────────────System Information───────────────────────────┐
│ Asterisk = ONLINE | Dahdi = ONLINE | MySQL = ONLINE │
│ BlueTooth = ONLINE | Hidd = ONLINE | NTPD = ONLINE │
│ PBX in a Flash Version = 1.7.5.5 │
│ FreePBX Version = 2.8.0.4 │
│ Running Asterisk Version = Asterisk 1.8.1 │
│ Asterisk Source Version = 1.8.1 │
│ Dahdi Source Version = 2.4.0+2.4.0 │
│ Libpri Source Version = 1.4.11.5 │
│ IP Address = correctly listed on eth0 │
│ Operating System = CentOS release 5.5 (Final) │
│ Kernel Version = 2.6.18-194.26.1.el5 - 32 Bit │
I think something is setup wrong somewhere in my network settings. I have been unable to find out what.
Things I have tried....
- disable and enable recommended stun settings from nerdvittles article ... no difference...
- tried changing port of 2nd extention to 5061 and left 1st at 5060 . If i change both the port in freepbx and the phone i cannot register if i change it only in phone i can register but i get random port 8XXX. I get the same 8XXX port if i leave all settings to 5060. the two local phones are behind a netgear router on a 2nd static ip that i have with the same provider.
I started looking at random files and found that sip_custom had the wrong external ip address so i corrected it and rebooted. This did not seem to help but this may not be the only file setup wrong.
I had to use netconfig to install since for whatever reason I could not get a valid ip during initial install. Netconfig setup (twice as usual) went thru fine and the install went on ok. But the weird 173.X.X.X ip that the install gave me before i ran netconfig was listed in the external ip. that may be a symptom of what is going on with my system.
Thru all this the system works for the most part.
Anybody have a idea where I should start looking?
merlyn
merlyn
