HP's New Microservers $349
wardmundy
Nerd Uno
HP's New ProLiant MicroServer $349
  • AMD Athlon™ II NEO N36L processor (1.3GHz, 15W, 2MB)
  • 1GB (1 x 1GB) PC3-10600E DDR3 UB ECC standard
  • Embedded SATA Controller with Embedded RAID (0, 1)
  • 1 HP 160GB Non-hot-plug LFF SATA Hard Drive
  • Embedded NC107i Single Port Gigabit NICs
  • Protected by HP Services and a worldwide network of HP Authorized Channel Partners. Warranty includes 1 year Next Day Parts replacement, 0-Years Labor, 0-Years Onsite support
Looks like $99 for second 160GB drive gets you hardware-RAID 1 out of the box. DVD Drive: add $49. Additional 2GB RAM: add $80.
In the UK, these are currently on offer for £134.88 (ex VAT) after £100 cashback.
HERE
Anyone built a PIAF/Asterisk box out of one yet? Only issue that springs to mind is the expansion slots look like they're half height. And they're PCI-E.
Think I would have preferred an Intel chip, but does that matter much nowadays?
I installed one two weeks ago, nice little server for small systems, there is four sata bays access from the front using a key top right.
I GB RAM with a 160GB SATA drive and supports RAID
the expansions are 1 half-height, half-length PCIe x16 Gen 2 1 half-height, half-length PCIe x1 Gen 2
Sorry for the late reply
I have two of the N36L's and have 3 landlines to connect to the Incredible PBX.
Any suggestion for getting the landlines working with it with a gateway? Any suggestion for the pci slot? Which do you think is the better solution.
These have £100 cashback on them again, making them a steal for a small system. If my maths is right, you can pick it up for an effective £87.49 ex VAT (after the cashback). Oh, and you can get up to a further 3% cashback via Quidco too.
For cards, you need half length, half height PCI-E. I've just picked up a 2nd user Sangoma A200DE which fingers crossed will do the trick. I'll then have a backup/development system for not very much money at all.
Anyone know if there's a network card driver in the current build of PIAF? It's an HP NC107i (BCM5723 chipset) apparently.
