Manager warning after 2.9 Upgrade...
nzimon
Just did the 2.9 upgrade and things appear to work correctly but the status display shows Manager Proxy Warning (yellow).
What's the deal? Is this fixable? What does it effect??
Thanks for the help!
Norm
Take a screenshot put it up here. I don't see what you are talking about.
Norm
That is a great picture describing Wardmundy and his fear of changes. That picture could also be posted on the thread(s) about faxing broken in Asterisk 1.8
Sorry, I was just kidding:lol:
nzimon,
My guess is the problem you have deals more with freepbx than with PIAF. Now that doesn't mean this forum won't help you - I've received a ton of help on all sorts of issues. I only mean to say that because you upgraded your freepbx to version 2.9beta, you will probably have a better chance of getting an answer if you post your question in their forum. :)
PIAF comes with the latest (stable) version of freepbx, and for that version and those older, most issues can be resolved by searching the PIAF forums.
Now with all that being said.... I will try to point you in a direction that has helped me on a similar problem with 2.9beta:
Try reviewing the Advanced Settings area of the new freepbx web gui.
Actually a lot of the FreePBX developers hang out here and help out.
mickecarlsson is one.
nzimon,
Hey Norm,
It's been about 5 hours since my answer to you - have you found what you were looking for or do you still need help?
