darmock
PIAF Developer
- Oct 18, 2007
- 2,891
- 97
:tazb:
I for do not mind helping out as time permits but lately it is like pulling teeth to get enough information to provide any answers. While some problems don't need an encyclopedia to solve it can't hurt.
BACKGROUND
Currently we have 32/64 bit ISO's and 4 colors of PIAF load files. Plus there are any number of incredible variants and older PIAF projects. I think I am not understating it when I say this can be a support nightmare.
Currently people donate their valuable time to the forums to help people out. Don't you think if you are asking a question that you should provide more than "I just installed PIAF and it doesn't work" and "Fix my broken box it worked before and now it doesn't" as a problem?
SOLUTION (maybe)
Because people donate their time I think it would be advantageous to provide a minimum of information about your system prior to describing your problem. We have provided several tools such as status and statustofile in PIAF just for this reason. So far one or two people have used statustofile and some people have posted the output of status.
Really this needs to change so please please please at a minimum post a capture of the status command with your question/problem. Realistically you should also post info like is incredible installed, hardware specs, and other salient details. This will save time and allow the people who are trying to help interact with more people.
Perhaps something like
-Status output (At least once per thread)
-Hardware profile (at least once per thread)
-Problem (at least once per thread)
Be as detailed as possible. Posting hundreds of lines of log files in multiple posts tends make the gurus eyes glaze over especially when it is the same output over and over. Please post only a few lines initially of a log file! If the gurus want more info they will ask for it.
-What steps you have tried to resolve this problem
Really just a point format is great!
SUMMARY
I think if these small changes occurred that the forums would operate more efficiently and the gurus eyes would not glaze over so much!
Just a few other points for newbies
If the first time you install PIAF and "it is broke" try a complete reinstall first prior to asking about your problem in the forums. Really this does help sometimes.......
Another point is if you have tried installing PIAF a few times and the problem still exists running update-source will not help at all and may compound your problem.
Did I mention that update-source is EXPERIMENTAL!!!!!
Sorry I really like this icon
That is it I am sure there will be flames.
BACKGROUND
SOLUTION (maybe)
SUMMARY
