chinesestunna
- Apr 24, 2011
- 4
- 0
Hi all,
I have searched up and down the internet and have exhausted everything I can think of that is wrong.
I have the following setup:
[Hardware]
Router: Asus RT-N16 running DD-WRT
Server: Standard VMWare RedHat 5 VM running PIAF Purple
[Status Output]
I have noticed something here. This is the log from a successful LAN XLite connection (I closed it first then reopenned):
When I try to connect remotely using the office network or Verizon 3G, nothing happens with the logs so it would seem the connection attempt never made it to the server. I have triple checked all ports mentioned in the guides such as 5060 and 10000-20000 have been forwarded to the PIAF server. In fact I've even put the PIAF into the DMZ but to no avail.
I did hypothesis that Comcast might be blocking 5060 and have read something about that and Vonage issues in the past so I have tried to forward something random like External port 15223 to 5060 on the PIAF server and switched the ports on my SipDroid client. This also did not work.
All SIP clients including SipDroid, XLite softphones and PAP2, work while on my LAN, wired or wireless.
What I'm trying to do is drop the PAP2 at my parents house so they get GV service.
They have the same setup:
Comcast Cable -> DD-WRT router (nothing special blocked)
The issue that I'm having is that I can't get any of the above devices to connect to my server while at their house, the error is registration timeout. I have the ports 5060&10000-20000 on my router forwarded to the Asterisk server so in theory everything should be fine. I have DDNS setup at my house so I've used both the externhost and externip settings on the Asterisk server but neither would work. I have also tried a different registration port other than 5060 but no dice.
I have followed this guide:
freepbx.org/support/documentation/howtos/howto-setup-a-remote-sip-extension
and read a few other guides along the same lines but still couldn't get it working.
Any thoughts PIAF Gurus would be great appreciated!
[Hardware]
[Status Output]
-- Unregistered SIP '701'
> doing dnsmgr_lookup for 'sipgate.com'
> doing dnsmgr_lookup for 'inbound1.vitelity.net'
-- Registered SIP '701' at 192.168.0.99:47528
> Saved useragent "X-Lite release 1104o stamp 56125" for peer 701
