Cannot get an inboud call, Outbound and internal are working fine
dbaddour
Hi all,
new system with new install, i have \
PBX= 1.7.5.6 Asterisk=1.4.40.2 and Dahdi 2.4.1.2+2.4.1
i have got internal calls going fine and i can call outbound. the issue now is i cannot make inbound calls. i have noticed from Dahdi show channels
they are all from " from-pstn" the other system that i have and in production now working "from Zaptel" i am using analoge lines into Digium card. running dahdi_genconf did not fix it.
what is the option to direct the system for get it from the zaptel not from pstn?
Am i correct this what is causing the problem for not making inbound calls
Thank you
David
Hi Wardmundy,
Just for what you saying anything with Zaptel is long gone with new versions? insteat it all replaced by DAHDI?
just to confirm.
Thank you
Hi again,
I followed this configuration to the teeth.. now i have no inbound or outbound calls,
run pbx*CLI> dahdi show channels
Chan Extension Context Language MOH Interpret
pseudo default default
that what i got?
Thank you
Go to this thread and run the script dahdi_report, post the dahdi-information.txt file here.
All done and the reort created, have it attached as txt doc.
Way to go that is a very nice tool to have and great work on your behalf..
Cheers
Eugene, you are genius.
inbound and outbound are great... I would like to have this thread open for a bit. as my next set now is to connect this system to other one thru the VPN since we have it in place for our 2 seperate physical location in order "hopefully" to make an extension call between the 2 seperate offices.
I would suggest starting a new thread on the VPN if you run into trouble (with VPN in the thread title). It makes it easier for others to help otherwise it can get lost amid the noise.
RandomPerson
