Upgrade from 2.5 to 2.8 - some problems
LesD
I am a new user of PIAF and still feeling my way. I have several queries but will post them one at a time.
The first is about my recent upgrade from 2.5 to 2.8
I have two PIAF systems - one to act as a backup. My main box was installed about a year ago at v 2.5 (FreePBX) but unused till recently. The backup was installed recently at v2.8.1.4 Wanting the two to be compatible, I decided to run through the upgrade tool and went from 2.5 > 2.6 > 2.7 >2.8.1.4 on the main system
All seems to have gone OK except for the following little problems.
1. The Module Admin page looks strange. Column 3 (Publisher) is overlaying column 1 - both are showing up in column 1 - and column 4 (Enabled) is in the position of column 3.
2. When selected, the Module Admin page always opens with 'Extended Repository' selected rather than 'Standard'
3. On the Outbound routes page, the drag/drop to reorder the route names does not work. They refuse to move.
4. Asterisk Logfiles does not show anything. CDR works.
My backup box, which initially was installed with 2.8.1.4 is fine.
The lack of a logfile listing is the most bothersome as I have other problems - to follow.
1. The Module Admin page looks strange. Column 3 (Publisher) is overlaying column 1 - both are showing up in column 1 - and column 4 (Enabled) is in the position of column 3. What browser are you in?
That is by design as PIAF has modules install from the Extended Repo.
Can you post the output of 'status' and/or 'statustofile' and the information in the link in my signature?
See my replies in red.
1 & 3: Chrome. I tried IE8 and problem solved. Thank you. But what is still odd is that from a different tab in Chrome, the same pages on my backup PIAF box do not have this problem.
2. Understood. Yes I did select something from the extended list on that box.
4. Sorry but I do not understand.
