darmock
PIAF Developer
- Oct 18, 2007
- 2,891
- 97
Ok some of you have been bugging me for this so here you go
Scheduled Release Date : April 23 , 2099 oops maybe that is not the right year..... hmmmmmm
Despite some of the more disparaging comment I have been subjected to as of late below is the change log for PIAF 1.2 both 32 and 64 bit versions.
32 bit is recommended for production machines only
64 bit should be experimented with prior to using it in production.
Each of the 2 new ISO disks support multiple install types and will install Asterisk 1.4 - production or Asterisk 1.6 Beta Edition - Experimenters only need apply
Thus in summary
The new Version of PBX in a Flash ISO will be 1.2
It comes in either 32 bit or 64 bit ISO's
Each ISO can install either Asterisk 1.4 production or Asterisk 1.6 BETA
**PLEASE NOTE The installation Asterisk 1.6 BETA can a very very long time. You really need a high speed connection to successfully install this as it is pulling quite a number of libraries to make it all work. I was going to put the libraries on the ISO's however it would have turned into a DVD so you will have to download them. I suspect once Asterisk 1.6 comes out of beta the install will speed up.
Here is the changelog. There is lots more stuff which I will document as soon as I get a chance to translate my programming notes to english
I hope this helps the testing has gone well thanks for all the support and it will be released before 2099.....
April 18, 2008
ISO's
- Remastered the 64 bit Edition of PBX in a Flash ISO
Based on Joe Ropers Original Work!
- Remastered the 32 bit Edition of PBX in a Flash ISO
- Changes to ISO's
Updated boot.msg to reflect expanded choices
Updated isolinux.cfg to reflect expanded choices
Added docs folder to ISO
Added a number of new install options. They are:
ks.cfg This is the standard PIAF - Asterisk 1.4 install using LVM formatting
ksalt.cfg This is the standard PIAF - Asterisk 1.4 install using EXT3 formatting
ks-sataraid This is the standard PIAF - Asterisk 1.4 install using simple sata - raid formatting *EXPERIMENTAL*
ksnet This is the standard PIAF - Asterisk 1.4 install but Centos is installed from a remote repository
ks16.cfg This is the standard PIAF - Asterisk 1.6 *BETA* install using LVM formatting
ks16alt.cfg This is the standard PIAF - Asterisk 1.6 *BETA* install using EXT3 formatting
ks16-sataraid This is the standard PIAF - Asterisk 1.6 *BETA* install using simple sata - raid formatting *EXPERIMENTAL*
Updated Centos to 5.1 and ensured rpm's are current as of today
PBX in a Flash Version 1.2
<Both Asterisk 1.4 and 1.6 versions>
- Added new download program which does the following:
Downloads the appropriate payload file from redundant sources and provides feedback if error occurs
Verifies that no transmission errors in the downloaded payload file have occured
Added method to do a local install - *NOTE* This feature is only available to PBX in a Flash Resellers/Partners
Verifies each file in the payload as being complete having no errors
- Rewrote build and compile program of PBX in a Flash to do the following:
All rpm packages are updated to the latest from our local repo
All source files that are contained in the ISO or Load files are updated to the latest
Added fix to allow music on hold to use MP3 files
Completely rewrote the install-pbx and install-pbx16 programs to provide a more consistent install process
Added "Painfully Detailed Logging (c) & tm" to the install process
Load files contain latest Digium source
Patch of Asterisk 1.4 Makefile to include the ASTCFLAGS+=DMYSQL_LOGUNIQUEID flag. Not applied to the 1.6 source
Load files contain latest FreePbx source
*Added all of the freepbx modules to the source. This will facilitate faster installs and less downloads.
Most programs moved over to source compile as opposed to install from binaries. This provides cleaner longer lasting install
All of the source files are installed on the PIAF system.
Updated pbx-help to reflect the new choices
Turned off pcscd by default. This process was causing some arcane problems on certain hardware platforms
Increased php.ini memory_limit to 100M
Increased php.ini max_upload_size to 100M
*Applied most of update-fixes to the source so you should *NOT* need to run update-fixes initially
PBX in a Flash - Asterisk 1.6 BETA only
- Initial release of program
- Contains all of the features of the 1.4 tree with the following exceptions
festival/flite/cepstral is *NOT* working *YET* (we hope to have a patch out shortly)
- Contains the very latest Digium 1.6 source
- Runs under 32 or 64 bit
- This is beta software if it doesn't work you will need to reinstall
- This is beta software if Dgium changes things and it stops working you need to contect Digium NOT the PIAF Development Team
- Did we mention this is beta software and it probably will only take up space on your hard drive
- Come on didn't you read it is beta software? This should not be used in a production environment *EVER*
* = will be implemented in the next pbx_load update!
Thus in summary
April 18, 2008
ISO's
- Changes to ISO's
start their whining it is simply time to have a party and make a much larger signal to noise ratio at this end and give any remarks the due consideration they deserve
