Only one outbound route?
PatchDog
I have purple install and working fine with 2 google voice accounts. I have added my POTS line coming in and used a linksys spa-3102.
I followed instructions from freepbx.org/support/docum...a-3000-freepbx
I have my Pots line setup first in my outbound routes and then my Google voice lines. When I try to make 2 outbound calls at the same time I get " all cuircuits are busy now".
How do I ensure that my google voice lines are picking up she slack on the outbound calls?
One other quick questions on a standard home line with call waiting. Is it clasiffied as 2 lines in and 1 out?
Thanks in advance. You guys rock!:confused5:
For home phone, 1 in and 1 out. Call waiting puts the other call in a "limbo" state. Not true 2 lines.
As for the 3102, in your outbound route, add the GVoice trunks under the 3102.
I do have the pots line first in my outbound route. Followed by my 2 google voice accounts below it. Could it be something else?
Anyone got any ideas why the google lines do not call out it the Pots line is 1st in the outbound routes?
If I move the pots line down the google lines dial out fine.
On the trunk settings for the analog line, did you set max channels to 1?
Bingo! You must set the channel limit in the trunk settings to 1. Otherwise, FreePBX will route the call to the SPA3102, which will reject it with a circuit busy message.
P.S. the SPA3102 is notorious for horrible echo problems. When you get tired of it, buy an Obi 110. And use the instructions on FreePBX.com to set it up.
