Remote SIP Phones cat't register
Markman1
Just moved my residence. New IP address. moved equipment (FreePBX 2.6.0.5 running PAIF). Same router same PC. No software changes. I have 4 remote SIP phones and 1 local SIP phone. I changed the Asterisk SIP Settings to reflect the new External IP. Changed the remote phones to reflect the new ip address as well. The "local" phone works fine, all the remote phones cannot register.
(Not sure if this has anything to do with it, but now my iPad will not connect to my wireless router either and it used to)
Can you help?
Can you help?
I would reset your router to defaults and try again.
New ISP, or different ISP? Does an online scan report SIP port 5060 (or whatever port you may have modified it to) as open? It's possible your ISP is blocking at their ingress point.
