Extend Superfecta LDAP lookup
hidalgo
I’m playing around with a PIAF purple and the Superfecta 2.2.5beta. Now I tried the LDAP source. I works fine but I’d like to have more infos than only the "cn". My LDAP server is Mac OS X 10.6 Server and I have attributes like: apple-company, sn, givenName.
If the caller has an entry in apple-company, i.e.. is a company not a person, I’d like to have shown something like apple-company - sn
How to do that?
Thanks a lot.
Glad that it works for you, I have only bench tested this in my lab, so a working report from the wild is welcome news :D
...but I’d like to have more infos than only the "cn". My LDAP server is Mac OS X 10.6 Server and I have attributes like: apple-company, sn, givenName.
How to do that?
Thanks a lot.
Line 110 hard codes an array of elements to return e.g. "cn"
We could test for apple-company and return different results. Is apple-company only set for company records, or will it be on all records ?
To see what elements you have to play with, change the "cn" array to
array(debug ? '*' : 'cn')
@lgaetz
Thanks a lot. It would be nice to have the choice to choose the fields to show up. Also the search (ou=, dc= …) should be free to enter. Not all LDAP servers has ous. ;-)
The OU is optional, just leave it blank if not required.
For v3.0 I have added a drop down list for different formats e.g.
  1. cn
  2. givenname sn
  3. sn, givenname
Are there any other formats you may require ?
Yes. ;-)
I would like to choose the fields depending the content of others.
In my case: if the field "apple-company" is not empty, show "apple-company - sn", else show "cn" or something like this.
Ok. I was wrong. The script contains the line:
$bd=@ldap_bind($ad, "cn={$run_param['LDAP_User']}, {$dc}", "{$run_param['LDAP_Password']}") or die ("Could not bind to {$scheme}://{$server}");
and I had to modify because of the hard coded "cn=", so I have now
$bd=@ldap_bind($ad, "{$run_param['LDAP_User']}","{$run_param['LDAP_Password']}") or die ("Could not bind to {$scheme}://{$server}");
This was the issue I talked about.
Yes. ;-)
OK, I will look into that for you.
After looking at the PHP function reference, could you try to bind with
$bd=@ldap_bind($ad, "uid={$run_param['LDAP_User']},cn=users, {$dc}", "{$run_param['LDAP_Password']}")
This works also.
I'm waiting thrilled about the coming version.
This works also.
Thanks for the feedback, I have added an option in v3 to switch between "Open LDAP" and "Apple Open Directory" methods for connecting.
v3 also adds the a drop down list of formats to use including "apple-company - sn" and "o - sn" which should catch most business entries hopefully.
If there are any problems parsing results, the "cn" entry is returned.
If there is enough noise generated I could always backport to 2.2.5, but I would prefer to carry on trying to get v3 ready.
