Hi all,
So i made a blunder of a move trying to restore an old PIAF build to a brand new purple install. the old one was running:
PBX in a Flash Version 1.4 Daemon Status
* Asterisk * ONLINE * Zaptel * OFFLINE * MySQL * ONLINE *
* SSH * ONLINE * Apache * ONLINE * Iptables * ONLINE *
* Fail2ban * ONLINE * IP Connect* ONLINE * Ip6tables * ONLINE *
* BlueTooth * ONLINE * Hidd * ONLINE * NTPD * ONLINE *
* Sendmail * ONLINE * Samba * OFFLINE * Webmin * ONLINE *
* Ethernet0 * ONLINE * Ethernet1 * ONLINE * Wlan0 * N/A *
* Running Asterisk Version : Asterisk 1.4.21.2
* Asterisk Source Version : 1.4.21.2
* Zaptel Source Version : 1.4.12.1
* Libpri Source Version : 1.4.10
* Addons Source Version : 1.4.7
Aaaaand the new fresh install is running this:
Asterisk = ONLINE | Dahdi = ONLINE | MySQL = ONLINE │
│ BlueTooth = OFFLINE | Hidd = OFFLINE | NTPD = ONLINE │
│ PBX in a Flash Version = 1.7.5.7 Running on *HARDWARE* │
│ FreePBX Version = 2.6.0.5 │
│ Running Asterisk Version = 1.8.6.0 │
│ Asterisk Source Version = 1.8.6.0 │
│ Dahdi Source Version = 2.5.0.2+2.5.0.2 │
│ Libpri Source Version = 1.4.12 │
│ IP Address = 192.168.5.161 on eth0 │
│ Operating System = CentOS release 5.7 (Final) │
│ Kernel Version = 2.6.18-274.3.1.el5 - 32 Bit
Sorry if the formatting is crappy. I really only wanted to move my extensions, trunk settings, ring groups, all routes, etc etc.. Just the basic configurations. But i may have just blown up my fresh install. Not a huge deal, i just have to redo the installer. My understanding is that the MONDO backup stuff creates images (.iso's) so you can reload exactly the machine you had. Wellll I want to upgrade everything to the most recent builds and move the config over. That doesnt seem to be happening. I have this message when i try to reload:
Checking for PEAR DB..OK
Checking for PEAR Console::Getopt..OK
Checking for /etc/amportal.conf ..OK
Bootstrapping /etc/amportal.conf ..OK
Parsing /etc/amportal.conf ..OK
Parsing /etc/asterisk/asterisk.conf ..OK
Connecting to database..OK
Connecting to Asterisk manager interface..OK
not writablePHP Warning: fopen(/etc/modprobe.d/dahdi.conf): failed to open stream: Permission denied in /var/www/html/admin/modules/dahdiconfig/functions.inc.php on line 1233
PHP Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/html/admin/modules/dahdiconfig/functions.inc.php on line 1235
PHP Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/html/admin/modules/dahdiconfig/functions.inc.php on line 1236
PHP Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/html/admin/modules/dahdiconfig/functions.inc.php on line 1237
PHP Warning: fwrite(): supplied argument is not a valid stream resource in /var/www/html/admin/modules/dahdiconfig/functions.inc.php on line 1273
PHP Warning: fclose(): supplied argument is not a valid stream resource in /var/www/html/admin/modules/dahdiconfig/functions.inc.php on line 1274
Wed, 02 Nov 2011 16:43:11 -0700 - Got event.. fullybooted
Wed, 02 Nov 2011 16:43:11 -0700 - No event handler for event 'fullybooted'
PHP Fatal error: Call to undefined method core_conf::addSipNotify() in /var/www/html/admin/modules/restart/functions.inc.php on line 23
1 error(s) occurred, you should view the notification log on the dashboard or main screen to check for more details.
Ater this I did amportal chown, bc I thought the freepbx upgrade might be causing this error. now when i hit apply on the reload button i get "Error: Did not receive valid response from server." I may have bricked the dam thing..
Any help or suggestions is appreciated.
Thanks,
Derrick
Thanks,
Derrick
