Ramblin
- Oct 28, 2010
- 138
- 9
I recently (on the weekend) updated to CentOS 5.7 and Asterisk 1.8.6 using the update-source script. I also updated the php using update100.
I did this on a 64-bit install that was originally a Piaf 1.7.5.5 and on a 32-bit install that was originally a Piaf 1.7.5.6
All seemed to be working fine until someone pointed out that the "Page All" feature (on the 64-bit system) was not working anymore. I tested the other (32-bit) system and had the same problem.
Everything else is still working fine. I can directly intercom (using *80<ext> ) and it works fine. All other features work fine. But when I use "Page All", the phones briefly connect, just long enough for the "Ping" to be heard and then the phones disconnect.
I am using Aastra endpoints, 53i and 57i, with v2.6 (latest v2 firmware). The issue is the same across all phones. And it was working perfectly until the upgrade.
The new php version is working fine; I have SugarCRM installed on the same server and it continues to work great.
My Status output is: (I have no ZAP connections, all SIP)
PBX in a Flash PURPLE Status
│ Asterisk = ONLINE | Zap/Dahdi = UNKNOWN | MySQL = ONLINE │
│ Fail2ban = OFFLINE | Internet = ONLINE | Ip6Tables = ONLINE │
│ BlueTooth = ONLINE | Hidd = ONLINE | NTPD = ONLINE │
│ PBX in a Flash Version = 1.7.5.6 Running on *HARDWARE* │
│ FreePBX Version = 2.8.1.4 │
│ Running Asterisk Version = 1.8.6.0 │
│ Asterisk Source Version = 1.8.6.0 │
│ Zap/Dahdi Source Version = N/A │
│ Libpri Source Version = 1.4.12 │
│ IP Address = 192.168.1.225 on eth0 │
│ Operating System = CentOS release 5.7 (Final) │
│ Kernel Version = 2.6.18-274.7.1.el5 - 32 Bit │
I have double-checked and the Paging/Intercom feature is still enabled (which it would have to be for the Intercom to still work, which it does) and the "Page All" code is stll what it was and is still in properly programmed into the "Page All" softkey. I also tried manually dialing the extension for "Page All" and the exact same thing happened: a quick connection, announced by the Page ping and then a disconnect.
Any ideas?
Any ideas?
