Travelinman for PIAF2 with CentOS6 install no work - SOLVED
amygrant
Set up a new piaf box and went to install travelinman:
wget http://incrediblepbx.com/travelinman2.tar.gz
tar zxvf travelinman2.tar.gz
./travelinman2.x
./travelinman2.x: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
Solution?
yum install glibc.i686
then the install works
        +------------------------System Information---------------------------+
        |  Asterisk   = OFFLINE | Dahdi     = ONLINE  | MySQL     = ONLINE    |
        |  SSH        = ONLINE  | Apache    = ONLINE  | Iptables  = ONLINE    |
        |  Fail2ban   = ONLINE  | Internet  = ONLINE  | Ip6Tables = ONLINE    |
        |  Disk Free  = ADEQUATE| Mem Free  = ADEQUATE| NTPD      = ONLINE    |
        |  SendMail   = ONLINE  | Samba     = OFFLINE | Webmin    = ONLINE    |
        |  Ethernet0  = ONLINE  | Ethernet1 = N/A     | Wlan0     = N/A       |
        |  PIAF Installed Version   = 2.0.6.2 Running on *KVM*                |
        |  FreePBX Version          = 2.9.0.7                                 |
        |  Running Asterisk Version = UNKNOWN                                 |
        |  Asterisk Source Version  = 1.8.8.0                                 |
        |  Dahdi Source Version     = 2.6.0+2.6.0                             |
        |  Libpri Source Version    = 1.4.12                                  |
        |  IP Address               = 192.168.1.20 on eth0                    |
        |  Operating System         = CentOS release 6.2 (Final)              |
        |  Kernel Version           = 2.6.32-220.2.1.el6.x86_64 - 64 Bit      |
        |  Incredible PBX 3 Version = 3.0.3                                   |
that version of travlin man was built only for 32 bit. We keep separate versions for 32 and 64 bit.
I have not had a chance to get in and rewrite travelin man to fit within the PIAF 2062 paradigm just yet. Let us know if forcing the install onto a 64 bit actually works.
I can verify it is indeed working. I always go here when I set up travelinman http://nerdvittles.com/?p=689
Just for future reference where can I find the 64-bit version?
I've just combed through the source, and I don't see anything that would cause this to fail on a 64-bit platform.
