SUGGESTIONS FreePBX 2.10 Latest Beta: Reload failed because of retrieve_conf error: 255
lescullen
Greetings folks,
apologies it this thread already exists as I could not find this bug.
I did a new install last Sunday of FreePBX in a flash on an old Proliant G4. The installation and deployment was flawless, with all extensions, trunks, conference, followme all working 100%...that was until I noticed that there were 14 new modules to install. After installing them I cannot RELOAD. I am a Newbie to Linux but do know some of the basic commands using Putty. Please could some benevolent and knowledgeable soul give me a clue where to look for the problem? many thanx!!
Reload failed because retrieve_conf encountered an error: 255
exit: 255
not writableAdded to globals: ASTETCDIR = /etc/asterisk
Added to globals: ASTMODDIR = /usr/lib/asterisk/modules
Added to globals: ASTVARLIBDIR = /var/lib/asterisk
Added to globals: ASTAGIDIR = /var/lib/asterisk/agi-bin
Added to globals: ASTSPOOLDIR = /var/spool/asterisk
Added to globals: ASTRUNDIR = /var/run/asterisk
Added to globals: ASTLOGDIR = /var/log/asterisk
Added to globals: CWINUSEBUSY = true
Added to globals: AMPMGRUSER = admin
Added to globals: AMPMGRPASS = amp111
Added to globals: AMPDBENGINE = mysql
Added to globals: AMPDBHOST = localhost
Added to globals: AMPDBNAME = asterisk
Added to globals: AMPDBUSER = asteriskuser
Added to globals: AMPDBPASS = amp109
Added to globals: VMX_CONTEXT = from-internal
Added to globals: VMX_PRI = 1
Added to globals: VMX_TIMEDEST_CONTEXT =
Added to globals: VMX_TIMEDEST_EXT = dovm
Added to globals: VMX_TIMEDEST_PRI = 1
Added to globals: VMX_LOOPDEST_CONTEXT =
Added to globals: VMX_LOOPDEST_EXT = dovm
Added to globals: VMX_LOOPDEST_PRI = 1
Added to globals: MIXMON_DIR =
Added to globals: MIXMON_POST =
[ERROR] Cannot open config file: /etc/asterisk/chan_dahdi_general.conf
[ERROR] Cannot open config file: /etc/asterisk/chan_dahdi_groups.conf
Remove the Dahdi module in FreePBX, and see if that fixes it.
Greetings folks,
exit: 255
Thanks for response. I had already tried that but problems persists as RELOAD not possible.. I have tried it for second time..herewith the result:
Reload failed because retrieve_conf encountered an error: 1
exit: 1
[FATAL] SELECT * FROM dahdi_configured_locations ORDER BY basechan [nativecode=1146 ** Table 'asterisk.dahdi_configured_locations' doesn't exist]
Trace Back:
/var/www/html/admin/modules/dahdiconfig/functions.inc.php:484 die_freepbx()
[0]: SELECT * FROM dahdi_configured_locations ORDER BY basechan [nativecode=1146 ** Table 'asterisk.dahdi_configured_locations' doesn't exist]
/var/www/html/admin/modules/dahdiconfig/functions.inc.php:452 dahdi_cards->read_configured_hdwr()
/var/www/html/admin/modules/dahdiconfig/functions.inc.php:184 dahdi_cards->load()
/var/www/html/admin/modules/dahdiconfig/functions.inc.php:34 dahdi_cards->dahdi_cards()
/var/lib/asterisk/bin/retrieve_conf:405 dahdiconfig_conf->dahdiconfig_conf()
1 error(s) occurred, you should view the notification log on the dashboard or main screen to check for more details.
What version of Asterisk and FreePBX please?
Have you reviewed this thread? :wink5:
For me, Asterisk Ver. 1.8.6.0. FreePBX 2.10. The thread you reference confuses me... I'm running Google Voice 0.0.9.... they talk about a 0.6? Is that right?
The FreePBX 2.10 updates are what blew you out of the water. Upgrade your GV version. The link is in the thread.
RockBottom..you are a STAR. First I disabled Dahdi as suggested by Atsak. That did not work. I have just disabled Google Voice as well and VOILA! Success. Thanks a ton I am really grateful. Best regards
Just to Restate What Is Now Obvious
Be advised, if you didn't already know, that FreePBX 2.10 is best suited for PIONEERS. The reasons should now be quite obvious. With the adventure come some risks...
