SOLVED IPTABLES keeps starting
moodinsk
Hi,
PIAF Installed Version = 2.0.6.4 under *HARDWARE*
I have disabled iptables via chkconfig.
root@pbx:~ $ chkconfig --list | grep iptables
iptables        0:off  1:off  2:off  3:off  4:off  5:off  6:off
But it keeps starting up randomly and throwing wrenches into my phone provisioning. My phones are on a seperate vlan and the default iptables config apparently hates this. This box has absolutely no connections to the internet so I am not worried about security. I suspected that it was a cronjob... but I dont see any job that would start it. I know the IPchecker script for travelinman3 caused iptables service to be restarted, but TM3 isnt intalled either.
Does anyone have any other ideas that I am overlooking?
Thanks.
You'll need to disable fail2ban as well.
I didnt mention this, but it is disabled via chkconfig as well
root@pbx:~ $ chkconfig --list | grep fail
fail2ban        0:off  1:off  2:off  3:off  4:off  5:off  6:off
From the time I first posted this, it started back up again. argh!
moodinsk
If you look in /etc/cron.daily/logrotate.piaf, you'll find service fail2ban restart . Just comment that line out and save the file.
