GOOD NEWS Latest yum upgrade broke FreePBX
Devil
Hi,
I just got done doing a yum upgrade through webmin, and now I'm unable to access FreePBX (it gives me a blank page) and Voicemail & Recordings (it says: PHP PEAR must be installed. Visit http://pear.php.net for help with installation.)
I could try the pear part, but don't know how to get to FreePBX without breaking the system further.
Please help, thanks!
using yum breaks everything! The only recommended way is by using the update-source program Which helps correct some of yum problems like resetting permissions on various files and folders
run update-scripts then update-fixes which may fix things
This only applies to PIAF 1.2 and above. If you are running a box that started out life as a PIAF machine less than 1.2 you will have your work cut out for you I am afraid.
Great, that seemed to have fixed everything!
Thanks a lot good sir.
One question though, I seemed to have forgotten what version this is. How can I find out?
status command
Great, it says:
* PBX in a Flash Version 1.2 Daemon Status *
* Running Asterisk 1.4 *
I guess I'm running 1.2. :)
Thanks, Tom.
Some feedback - I ran update-source, update-programs and update-fixes on PIAF Green with FPB 2.11 and it works perfectly. I am now on Asterisk 11.5 with no issues (so far).
Damn a new record this thread is 5 years old! And for PIAF 1.2! Thanks for the report however
