BUG Incredible Fax 11 No Worky
kdaffef02
Ward & Dev Team : Thank you for your hard work !!
I'm back because I'm not able to make Incrediblefax11 sending faxes : tried many days in googling and searching in Piaf Forum, but no way to get this Ok ??. :banghead:.
All seems working : Green Piaf fresh install, Incrediblepbx11, Hylafax, iaxmodem and avantfax : I can receive (a fax did point to hylafax custom destination but no way to send !. The iaxmodem are shown like "online" Cli, but seem "not registred" in var/log/iaxmodem/iaxmodem-cfg.ttIAX.. : ???. Another element : when a fax is scheduled, it will started only after a reboot !! ...
all fax numbers tested with avantfax have been already verified before with my phone that have a fax signal on the other end.
Here is my config :
PBX in a Flash GREEN Status Program
┌────────────────────────SYSTEM INFORMATION───────────────────────────┐
│ Asterisk = ONLINE | Dahdi = ONLINE | MySQL = ONLINE │
│ Disk Free = ADEQUATE| Mem Free = ADEQUATE| NTPD = ONLINE │
│ PIAF Installed Version = 2.0.6.5 under *XEN* │
│ FreePBX Version = 2.11.0.11 │
│ Running Asterisk Version = 11.7.0 │
│ Asterisk Source Version = 11.7.0 │
│ Dahdi Source Version = 2.8.0.1 │
│ Libpri Source Version = 1.4.14 │
│ IP Address = XXX.XX.XX.XXX on eth0 │
│ Operating System = CentOS release 6.5 (Final) │
│ Kernel Version = 2.6.32-431.1.2.0.1.el6.x86_64 - 64 Bit │
│ Incredible Version = 11.7
- Hylafax+, iaxmodem : started
- Iaxmodem configuration (in I use alaw everywhere as we are in Europe. use ulaw instead ?) :
device /dev/ttyIAX2
owner uucp:uucp
mode 660
port 4572
refresh 300
server 127.0.0.1
peername iax-fax2
cidname Incredible PBX
cidnumber +00000000002
codec alaw
- Iax2 extension(in iax_custom.conf)
[iax-fax2]
type=friend
host=127.0.0.1
port=4572
context=from-fax
requirecalltoken=no
disallow=all
allow=alaw
jitterbuffer=no
qualify=yes
deny=0.0.0.0/0.0.0.0
permit=127.0.0.1/255.255.255.0
- Iax settings (iax_general_additional.conf) :
mailboxdetail=yes
tos=ef
disallow=all
allow=alaw
requirecalltoken=no
qualify=yes
codecpriority=host
delayreject=yes
jitterbuffer=no
minregexpire=60
maxregexpire=3600
- config.ttyIaxX2 (in /var/spool/hylafax/etc, tried with and without country & area code but no way !!)
#CountryCode: 1
#AreaCode: 800
FAXNumber: +1.800.555.1212
#LongDistancePrefix: 1
#InternationalPrefix: 011
DialStringRules: etc/dialrules
ServerTracing: 0xFFF
SessionTracing: 0xFFF
RecvFileMode: 0600
LogFileMode: 0600
DeviceMode: 0600
RingsBeforeAnswer: 1
SpeakerVolume: off
GettyArgs: "-h %l dx_%s"
LocalIdentifier: IncredibleFax
TagLineFont: etc/lutRS18.pcf
TagLineFormat: "From %%l|%c|Page %%P of %%T"
MaxRecvPages: 200
- iaxmodem (/var/spool/hylafax/log)
from Jan 03 15:21:11.17: [ 2120]: SESSION BEGIN 000000012 0147003234
Jan 03 15:21:11.17: [ 2120]: HylaFAX (tm) Version 5.5.3
Jan 03 15:21:11.17: [ 2120]: SEND FAX: JOB 6 DEST 0147003234 COMMID 000000012 DEVICE '/dev/ttyIAX2' FROM 'kdaffef <[email protected]>' USER maint
Jan 03 15:21:11.17: [ 2120]: STATE CHANGE: RUNNING -> SENDING
Jan 03 15:21:11.17: [ 2120]: <-- [12:AT+FCLASS=1\r]
Jan 03 15:21:11.17: [ 2120]: --> [2:OK]
Jan 03 15:21:11.17: [ 2120]: MODEM set XON/XOFF/FLUSH: input ignored, output disabled
Jan 03 15:21:11.19: [ 2120]: DIAL 0147003234
Jan 03 15:21:11.19: [ 2120]: <-- [15:ATDT0147003234\r]
Jan 03 15:21:56.20: [ 2120]: --> [9:NO ANSWER]
Jan 03 15:21:56.20: [ 2120]: SEND FAILED: JOB 6 DEST 0147003234 ERR No answer from remote {E003}
Jan 03 15:21:57.20: [ 2120]: <-- [5:ATH0\r]
Jan 03 15:21:57.20: [ 2120]: --> [2:OK]
Jan 03 15:21:57.20: [ 2120]: MODEM set DTR OFF
Jan 03 15:21:57.20: [ 2120]: MODEM set baud rate: 0 baud (flow control unchanged)
Jan 03 15:21:57.20: [ 2120]: STATE CHANGE: SENDING -> MODEMWAIT (timeout 5)
Jan 03 15:21:57.20: [ 2120]: SESSION END
-Log var/log/iaxmodem/iaxmodem-cfg.ttyIAX2
[2014-01-03 14:00:53] Registration failed.
[2014-01-03 14:05:48] Registration failed.
[2014-01-03 14:10:43] Registration failed.
[2014-01-03 14:15:38] Registration failed.
[2014-01-03 14:20:33] Registration failed.
Any help is highly appreciatedo_O
Haven't gotten to the fax issues yet... but you knew that, didn't you??
Hi Ward and thank you for your reply,
I think that i have the issues but not able to get that fixed even with a whole forum reading !!. but Incrediblepbx, is very really beautiful
Hi for all memebers,
no idea to get just one incrediblefax 2 or 11 working (send and receive) ??
No hope :-(
Hi again,
I use Piaf in XEN virtual environment (www.hostvirtual.com)
I have tried a lot of time to get working incrediblefax11, but no luck with fine configuration.
However, I didnt succeed to get this working anyway :-(
on the another hand, I learn this :
url : https://wiki.debian.org/HylaFax#Xen_.2F_Virtualisation
Xen / Virtualisation
Warning - It is possible that Hylafax may have problems running in a virtual environment. Fax sending and receiving is very time critical. There has been numerous cases where a setup is fine but the virtual environment causes failures that are hard to diagnose.
So i think that the problems are linked only to XEN virtual environment.
Sorry for my stupid questions, and Thank you for your great support !.
Kamel
