TRY THIS Fax not working after migrating to new machine
docgreen
I just moved my PBX from an old Dell tower to an Asus Eee PC using the Incredible Backup/Restore method, and so far everything has worked perfectly...
...except for faxes.
When I click on the AvantFax button in the main menu, I get a blank screen.
The Winprint HylaFAX GUI isn't able to connect to the server.
If I try to run install-incredfax2 it tells me that the install has already been ran.
I'm at a loss... not sure what to do to fix this. Any ideas?
FWIW, everything else seems to have worked flawlessly. All the extensions are working, IVR and recordings are all good, inbound/outbound calls are good... hell, even the Google Voice trunks are working!
Incredible doesn't pick up the fax apps themselves. Just run the Incredible Fax installer again, and all should be fine.
Tried that, but it tells me that the installer was already run once, and can't run again. Is there a command argument I can use to force it torun again?
Here's a thought... the Incredible Backup assumes that you have a freshly installed PIAF to restore to... but if I'm restoring Incredible Fax as well, do I need to pre-install it as well before running Incredible Restore?
OK, I re-built the PBX on the new machine. This time after doing the clean install (using a freshly-download ISO) I also installed IncredibleFax.
THEN after making sure all the modules were installed and updated, I went ahead with the IncredibleRestore.
Again, phones are working as they should after the restore, but the fax still isn't working. It's "better" than it was... I can get to the AvantFax menu now, and it shows all my previous faxes, but now the modems all say "[please wait]."
It's the end of the holiday weekend and I'll be resuming normal business hours tomorrow... if anyone has any ideas about what to try to get this running, I'd be greatly appreciative!! Thanks in advance!
Ward, could you move this thread to a more appropriate category? Not sure why it's in "Trunks," I thought I had posted it in "Help."
I'm curious - did you get this resolved?
I'm in a somewhat similar situation - did a new install, set it up, then ran incrediblefax.. I can config & *RECEIVE* faxes, but can't get the avantfax menu to show up, and am not sure how to trouble-shoot it...
any tips are greatly appreciated....
I "resolved" it by scrubbing the new install (for now) and just going back to the old box.
Once I have more time I'll resurrect the new install and just manually copy all of the settings and everything.
